I want to upload an 80MB file to either my site via FTP or any method or to something like YouSendiT but my transfer speed is 40kbps at best. I don't want my browser or FTP client to timeout as a result, so what can I do to avoid that problem?
Iknow with Mozilla Firefox you can disable timing out. Other option is a faster connection. I have the same problem. My max up is like 60 kb yet I know folks that claim almost a Meg /sec
No DVD can withstand the power of DVDShrink along with AnyDVD!
Hi,Originally Posted by Garibaldi
take a look at yourinternet options under connections under setting>properties>options... the title of the window should your "isp" settings .....
there a setting to change the idle time before it disconnects..... by default it about hour!! many times even though your uploading or downloading.. some dialup willnot recognize that as being a active condition but a idle condion.. smile... I would probably chang it to either never, 8 hours or 24 hour setting...!
in your case 80 megs on a analog dialup!! , if at one shot, that going to be about a at least 6 hours upload time!!!! that a awfull long time for a analog connection to stay good... ie ; noise issues interferring or glitches onthe net... grrr. smimle.... good luckk!!
I'd say split them into 1 meg chunks and upload them separately.
I'd say put a .torrent file on your website and tell people to get Azureus. Then you won't have to worry about diskspace on your web server or interrupted uploads. The file will be available to anyone as long as you, or anyone else who has downloaded the video already, have their PC on.
Terje A. Bergesen
utorrent. Azureus is a resource hog after it has been running for a little while. (70mb ram usage versus 5mb for utorrent)
Post a data CD to your host provider, and ask them to load it.
Movie timing is off for files converted to DVD
By wildgeese in forum ffmpegX general discussionReplies: 6Last Post: 18th Sep 2011, 11:45 -
NET files
By mickdee259 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2009, 15:28 -
Join mov files and upload to youtube
By neelapala in forum EditingReplies: 2Last Post: 23rd Dec 2008, 11:09 -
Trying to convert my vob files for upload to youtube.
By Aly199 in forum DVD RippingReplies: 8Last Post: 3rd Jun 2008, 06:22 -
Mpeg too large to upload on youtube?
By nadizo in forum Video ConversionReplies: 2Last Post: 31st Oct 2007, 15:13
