I have vcds, but i want to rip the .dat files and burn them as data dvds. Will the player be able to play the files?
EDIT: Ill use vcdgear and use convert bin/cue to dat..Or is mpeg better?? Im confused..someone please help..
Results 1 to 11 of 11
Thread: Question about Phillips DVP-642
My 642 will play the mpgs on a data disc DVD...
Ok, so ill convert the bin/cue to mpeg in vcdgear. I heard vcds work on the dvp-642, that means its reading the dat file..So what should i do?
Bssically you want to get the mpg from the bin and just burn that as a data disc. I've never used VCDGear but since it's freeware - nothing would be lost in trying
You can also burn to an RW for testing.
If you have ISO Buster, try this
http://www.videohelp.com/forum/userguides/141726.php
Will the player play MPEG and MPG, or just mpg?
Yes, you can put several DAT files (from VCD) on ISO data DVDs and the 642 will play them. There's no need to "convert" to MPG.
Thank you
I will just use vcdgear and do cue/bin -> .dat
Oh cool, I didn't know that. 8)Originally Posted by jagabo
There's no difference. They are the same thing.Originally Posted by Moloko_Plus
The DVP-642 will play raw data discs, so you can burn DAT files or MPG files to DVD as a data disc and it will play them. It will play MPEG4 on DVD data discs also. I wouldn't be surprised if it would play raw VOB files too, but I've never had a reason to try that.
I tried a 16:9 VOB file from a DVD -- it played but it was 4:3 with the edges cropped. I didn't have a chance to check the players settings. So I'm not sure if it will play SVCD files with the right aspect ratio. I'll see if I can find one for at test later.
I wouldn't expect it to play SVCDs in the right aspect ratio. One of the big downsides to this player is that its SVCD support sucks. It supports only a subset of the format's specifications. For example, it won't support a secondary audio track or more than 1 subtitle stream, even though the format specs allow for 2 separate, selectable audio tracks and up to 4 selectable subtitle streams. In fact, if the player finds subtitles on your SVCD, it will play the first stream and it can't be turned off! Thanks Philips.
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
Question about Phillips DVP 5960
By hootal in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Jan 2008, 11:57 -
how to encode MPEG4 to play on a phillips DVP-642 player
By thejunkman12 in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2008, 08:32 -
REMOVE Phillips DVP-642 "angle" indicator
By gumbico in forum DVD & Blu-ray PlayersReplies: 35Last Post: 28th Jun 2007, 12:55
