VideoHelp.com Forum
  1. Member MISS CHIEVOUS's Avatar
    This is a cheap unit that a friend gave me as a gift about a year ago but I think it has died (?).
    My title says it all --
    After watching a movie a few days ago, I did the following:
    Ejected tray
    Removed movie
    Replaced with next movie to watch
    . . . and then, right around this point
    I hit the OPEN/CLOSE button on the remote to close the tray and watch movie #2.
    The screen switched to black & white and (what was the blue "screensaver" title page) is now scrolling furiously.
    I've unplugged the unit from the way.
    I've tried various buttons to reset it.
    I've unplugged the S-Video cable.
    I just want to know for certain it's dead before I proceed to buy another player.
    MC
    Black and white of a sudden and scrolling sounds like PAL movie playing in a NTSC player. I would try other movies before certifying it's dead.
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin).
  3. Always Watching guns1inger's Avatar
    You may have changed a setting by mistake, either through a menu or a physical switch, telling the player to output PAL for all material. Otherwise the screen saver should have been normal. If it switched to PAL automagically when a PAL disc was inserted, perhaps playing an NTSC disc will set things to right ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Member classfour's Avatar
    Had a similar experience with an Apex 2600: It had switched itself from S-VHS output to RCA composite. Connect it with the opposite output and see if you get a signal. If so, switch the output in the menu - assuming it's not in PAL mode as earlier.
  5. Member MISS CHIEVOUS's Avatar
    Hi guys, wow thank you for all this advice! classfour and guns1inger . . .
    I tried inserting an NTSC movie, but it just keeps scrolling.
    When you say "Connect it with the opposite output ~" I'm afraid I don't know what that means.
    Could you be (very, lol) specific please? And please be aware, I can't grab anything because of the hyper scrolling. If there is something I can do with my TV setting, please let me know? Thanks guys!
    MC
  6. Member MISS CHIEVOUS's Avatar
    40 minutes later . . .
    Well I just learned something (not that it's going to make a damn bit of difference lol): This issue is definitely related in some way shape or form to the cable I'm using — namely, the little S-Video cable.
    I just did an experiment by (turning off both TV and player and then) unplugging both ends of the S-Video cable, and connecting the player to my TV with the original coaxial cable. It didn't bring my picture back; but it changed the appearance of the garbage it was dumping from hyper scrolling to a (rather attractive lol) black and white herringbone pattern. Alas, I'm not fitting a suit; I'm trying to watch a movie. :P
    Now, I've got another DVD player that I got free that never worked (brand new, sealed box) from the get go and while I hope for further replies to this thread I'll hunt down repair strategies for that model (an APEX AD-1165, no thanks to Viking office supplies who unloaded it on me tsk). The problem with that unit is (if I remember correctly) the tray won't stay closed.
    So I'll do some more sleuthing. I now have three non-functioning DVD players (count a Cyberhome CH-300).
    MC
    I notice you found the Desay website, such as it is. If you search through (manually) the subsequent pages you may find other tips like this
    Player is fine, reads everything. I hope Desay has tech support for firmware upgrade in the future.
    If you have an NTSC TV, make sure you do the following:
    1. Press Setup on remote.
    2. Go under Preferences -> TV Mode
    3. Make sure the mode is on NTSC!! (The default mode/factory setting for the DVD player is Multi. This will cause the scrolling black and white picture on some VCDs and PAL DVDs!!!)
  1. Sudden audio loss on avi file
    By jruston in forum Audio
    Last Post: 16th Oct 2010, 14:55
  2. Replies: 0
    Last Post: 15th Aug 2009, 19:20
  3. Color loss, even when doing lossless?
    By roper512 in forum Newbie / General discussions
    Last Post: 12th Apr 2009, 18:00
  4. Desay dvd player to view on my computer ...how?
    By Boothbay in forum Newbie / General discussions
    Last Post: 4th Mar 2008, 11:58
  5. Video8 Color loss
    By briannc in forum Restoration
    Last Post: 18th Jan 2008, 14:14
