I have some DV AVIs (NTSC - 720 x 480) I'd like to convert to Flash Video Format.
I notice when converting the videos with the Flash 8 Video Encoder - I can resize the videos, but they come out to 320 x 213 (I'd like the video to be the standard 320 x 240 size).
So I have two options that I know of, either uncheck the Maintain aspect ratio option and just resize it to 320 x 240
or
Choose the crop and trim function, crop off 40 pixels each side (to 640 x 480) and then resize the video to 320 x 240 (thus maintaining the aspect ratio).
Any tips on which way I should go or another workaround for this?
Is 320 x 213 a standard video resolution???
Thanks!
Short answer: Do the 1st one.
That's actually the way I've been doing it.
I have a question if you care to answer - when I export my video project (NTSC 720 x 480) from Premiere Pro to something like Windows Media (320 x 240 size) - is this what "automatically" takes place?
Probably.
This is what may be going on behind the scenes (at least "should" be going on):
1.De-Interlace (one of many ways) --as needed (which it usually is when going to web-ready WMV)
2. Crop 720x480 -->704x480 (removing overscan)
3. Resize (Precise Bilinear or Precise Bicubic or Lanczos) 704x480 --> 640x480 or 320x240 (Maintain AR, convert non-square pixels to square pixels)
4. Colorspace conversions, as needed (RGB or 4:4:4 or 4:2:2 or 4:1:1 to 4:2:0--usually)
How to record streaming flash video, edit and save as AVI, MP4, FLV,etc.
By Baldrick in forum User guidesReplies: 2Last Post: 18th May 2012, 10:48 -
How to convert .flv (flash video) to .avi or .mpg
By hitrec in forum User guidesReplies: 181Last Post: 17th Apr 2010, 16:14 -
Flash Professional converting to FLV
By PowerFalcon in forum Video ConversionReplies: 14Last Post: 4th Jul 2009, 09:00 -
Batch Converting of Varouous vide fromats to Flash flv with ffmpeg
By tempgp in forum ProgrammingReplies: 0Last Post: 7th Dec 2007, 15:58
Statistics
Newest guides
Latest tool updates
New media comments
