VideoHelp.com Forum
  1. My cable box is a HD Scientific Atlanta Explorer 2000. It has two Firewire ports on it. Can I connect the Firewire port to the Firewire port on my PC without causing damage? I know the Firewire is sending a video signal and I would like to capture it with my Ulead DV software I use to capture from my DV camcorder through the Firewire.
    Is this possible?
    Perhaps. Chances are you won't be able to have it recognised as a camera, so you will have to use a transfer app that can just grab the DV stream. I know Vegas can do this if you turn off device control.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Ok, I connected it up and my Monitor turned a blue haze. I disconnected it ASAP, but my Monitor is still a blue haze. I shut down my PC, then booted it back up. It is still a blue haze, even while it is posting.
    Any ideas?
    I am surprised it affected your monitor if it was just going into your firewire card. Are you sure you didn't bump another cable while plugging things in and out ?
  5. Член BJ_M's Avatar
    im surprised those ports are active - most cable companies have not activated them
  6. Dohh! I tighten the video cable and it worked fine.
    I've got my Motorola 6412 connected via firewire to my HTPC and it works great. I can capture anything but premium channels (HBO, CineMax, etc.) But I can capture the INHD channels and any other HD channels in Hi-Def.
    You need a couple of programs and the drivers to make it work.
    There's thread on avs forum about it...not sure if your box is supported or not.
  1. Connect LCD monitor to Digital HD Cable box?
    By rogerconnery in forum DVB / HDTV
    Last Post: 18th Jan 2012, 06:04
  2. How would I connect my standard cable box to my HD LCD monitor?
    By Jadedrain_06 in forum Video Conversion
    Last Post: 27th Nov 2011, 12:00
  3. Anyone ever connect their cable box to a projector?
    By True Colors in forum Newbie / General discussions
    Last Post: 31st Jan 2010, 13:53
  4. How to connect a monitor to a digitanl cable box?
    By Latvian in forum DVB / HDTV
    Last Post: 3rd Dec 2008, 00:47
  5. Replies: 2
    Last Post: 25th Mar 2008, 18:47
