I obtained an AVI which had VBR MP3 as the soundtrack.
Attempt 1: Auto convert using AVI2DVD, the resultant DVD plays fast/slow/fast/slow. Useless.
Attempt 2: Saved soundtrack separate from AVI using VDubMod. Convert to AC3 using Belight (48K sampling rate and all that) Used GUI for DVDAuthor to combine it all and author it back into DVD structure. Result again: fast/slow/fast/slow.
I *think* it's the AC3, but I can't seem to convert it right. Belight showed no errors, and MPC seems to play it just fine.
Attempt 3: Went back to VDubMod, did "full processing" this time and saved the soundtrack as uncompressed PCM wave. Got a HUGE file this time (like 1.6 GB) so it looks right. Used Belight to compressed this into AC3, 48KHz, and all that. Got a 400M file, so I guess that's about right. Used GUI for DVDAuthor to combine it again. And decided to read the log this time. HUH?
During the authoring phase, EVERY sector of the audio reported a warning about audio out of range on EVERY LINE? It finished just fine. Got a DVD this time that burns fine. However, when I play it, the sound cuts in and out, in and out. The dolby light goes on for a few seconds, off for a few seconds (no sound) then back on, so on and so forth (on the DVD player).
The warning was:
WARN: audio sector out of range: -xxxxxx (vobus #xxxx, pts xxxx.xxxx)
It's doing this on almost every vobu (vob unit?)
What should I do?
Results 1 to 15 of 15
NOTE: At the end it says
WARN: audio sector out of range: -1120268 (vobu #15870, pts 4863.4934)
STAT: fixed 15871 VOBUS
INFO: dvdauthor creating table of contents
INFO: Scanning C:\Program Files\GUI for dvdauthor\OutDir\DVD/VIDEO_TS/VTS_01_0.IFO
So I guess those warnings don't mean anything, but why doesn't the DVD, when burned, play right?
deleted
Uh, did that. (See attempt 3)
AAC not going to work to make a dvd - and mp2 doesnt work on all dvd players
Argh! This thing is KILLING me! (almost)
I have ONE AC3 file that is playing properly (plays in sync with the m2v) (incidentally, it's 5 seconds longer than others, weird...) and I'm going to try to convert THAT to MP2, then mux that with the GUI...
Dang, this is WEIRD. Burned a new DVD with the MP2 as sound track. PowerDVD plays it fine.
Put the same DVD in the DVD Player (Pioneer 525, old but good) and it does the same thing: sound cuts in and out, in and out, in and out.
Thought I had a bad authoring program, so I tried SimplyDVD, which is like a ultimate simple GUI to DVDAuthor... But that DVD, with MP2 sound track, also did the skipping sound thing.
So far, I've had 6 coasters. It's NOT the media since it plays fine on the PC, and I've tried both Imation AND no-name Staples media (which has FUJIFILM03 media code!)
Any other ideas?
have you checked your bitrate of your mpeg file?
deleted
oh - ok .....
wav is the best choice instead of more lossy formats - but i see your drift ..
funny enough ... it is a lot of the pioneer players that do not play mp2 audio"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
M2V is fine. Actual size is under 4 gig, bit rate average is about 3700 (max is 8000, right?) compressed with HCEnc, originally through AVI2DVD.Originally Posted by BJ_M
It's the audio that's killing me.
Any way, I got so tired I went ahead and downloaded VSO Divx to DVD and used that (and that worked just fine, bless VSO), and the DVD just burned... Putting it into DVD player now... Works just fine. *sigh* 8)
8000 is often to high for some encoders and media combinations .. for burned media ... 8000 would have been for sure to high with the wav files .... i suspect it was (in part) the video files that were causing the drop outs in your audio files -
with out a sample - it is only guessing at this point ... but this is not an unusual thing ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I figured out the problem. AVI2DVD is VERY VERY VERY picky about the file names. You have to take out the extra periods, dashes, parens, and so on.
I've taken out the extra periods, dashes and all of that but I still have the same problem
in the bigenning it seems fine but after a while "the out of sync problem" comes again
I really liked avi2dvd because it converts in exellent qualities
I tried convertxtodvd but the result is cheap quality even if I choose the high quality option
so is there any way to solve avi2dvd problem ?
Quite frankly - after years of AVI to VCD/SVCD/DVD hazzle (a hit&miss procedure at best, as AVIs are rarely encoded with the conversion to other formats in mind, in the first place!) I got a DivX capable player. Never had any reason to fiddle days on end with stubborn conversions since that day. A 30 Euro investment that saves you a lot of trouble and time.
/Mats
Problems with my VHS/8mm/MiniDV to DVD project
By compgl in forum CapturingReplies: 6Last Post: 15th Jan 2010, 09:30 -
Adobe Encore DVD 2: Copy from project to project?
By JolleJ in forum Authoring (DVD)Replies: 1Last Post: 15th Sep 2006, 11:10 -
5.1 audio to dvd project help
By tomoftenville in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2005, 14:53 -
Audio files in DVD Project
By CloudEmeron in forum Authoring (DVD)Replies: 0Last Post: 2nd Jun 2004, 18:23 -
New Project has audio sync problems
By in forum CapturingReplies: 1Last Post: 6th Jul 2003, 19:01
Newest guidesLatest tool updatesNew media commentsVSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
