VideoHelp.com Forum
Poll: My standalone DVD Recorder is a
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 30 of 32
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    No, I record using a PC with Capture Card
    Same as Baldrick
  3. I have used many capture ystems. I have found that our latest Panasonic has the greatest "Wife Acceptance Factor" of all of it.
    Maybe if I get my HTPC sorted out that might be better but I have a sneaky suspicion it won't - say unless DNNA's ReplayTV cPC software comes out much better than people are hoping or Yahoo makes the Meedio to Yahoo Go software a killer app.
    Panasonic DMR-ES45VS, keep those discs a burnin'
  4. Member yoda313's Avatar
    We need another option of "I USE BOTH A STANDALONE AND A CAPTURE CARD".
    I have a LITEON 1107HC1 that I like a lot. Its - and + RW and has firewire in. It doesn't have a stereo rf tuner but you can record stereo off of a stereo vcr through av inputs. Its a clean simple design and playsback divx as well.
    For stuff I want in stereo I capture on the pc with my fusion hdtv gold t 3 capture card. Then I burn with my new pioneer 111
    I mainly use rw's on my dvd recorder and stuff I want to save I rip to the pc and edit it to a nice -r or +r disc to keep
    The 3 hour mode is acceptable quality for archiving in my opinion. The 4 hour and 6 hour modes are really meant for marothons you intend to watch once and not keep imo. The 6 hour mode is watchable but its vcd mode and not much better than videotape. But the 6 hour isn't pixalated so its still acceptable for occasional use. Maybe for sports recordings you just want to watch once but not repeatedly.
  5. ** Pioneer DVR-220-s -- (r/rw only)
    ** Polaroid DRM-2001G -- (r/rw and 80g HDD) -- review comming..
    ** iLO DVDR04 -- (r/rw only)
    -vhelp 4046
    VHELP's - Sample Clips [last: 12.29.06],
    my YouTube videos
  6. Member hech54's Avatar
    I have one of the few Philips DVDR985's that is still alive and kicking....amazing huh?
  7. I have a Philips DVDR70 and a Capture card (only to watch TV). I record on standalone (much faster) and author with PC.
  8. Member yoda313's Avatar
    Correct me if I'm wrong but don't all recorders (including capture cards) record at 1x realtime?
    Now if you mean actually getting on a dvd right away is faster with a settop than yes of course. That is one nice thing about the settop units. You can record straight to disc without waiting to author later. And if you want to do some editing just rip it to the pc and reauthor it
  9. DVD Ninja budz's Avatar
    PIONEER 220-S
  10. Member Bodyslide's Avatar
    ILO dvdr04 and Liteon 1105
    I record on TIVO and or RePlayTV DVR and then if it is something I want to keep record it on one of two set-top DVD recorders.. an Ilo [LiteOn] or Magnavox[Philips].
    --David
    Can't put in 2 (or more) recorders. I use a Panasonic as well as a Liteon.....
    I don't record so far. If I wished to do, I've got a capture card.
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin).
  14. Member lumis's Avatar
    I actually do a few of those things.
    I record to my DVR & DVD-RW. If it is something that is kind of unpredictable as to the length, I'll take an educated guess how long it will run, minus commercials, and then re-record it while playing it back from the DVR with tweeked settings on the dvd recorder if needed.
    I use a Pioneer DV-220/225, which allows you to change your record mode by 10 minute incriments, thus allowing you to use the majority of the disc instead of getting stuck with 1/2/4/6 hour record modes.
    I will also do some quick & dirty captures with my analog video capture card, but the ease & quality that the DVD recorder allows has almost eliminated this.
    I do plan on purchasing an OTA HDTV capture card in the future, just not sure what to get yet.
  15. Member MJA's Avatar
    ILO04 so my vote went to liteon.
    who makes Polaroid DRM-2001G by the way?
  16. Member Marvingj's Avatar
    I have several Toshiba SX-34, D-4; JVC dm-10; Panny ES-10; Pioneer 225, 520-H....I use them all for different things.. Have some others that I have personal put Hanglose around that gave me trouble & an example to the rest that they can also hang if the screw up a recording.
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
  17. who makes Polaroid DRM-2001G by the way?
    I can say this much..
    It uses familiar LSI Logics DoMiNo Media Processor and YesDVD software.
    IMHO, the picture quality is definately good. More bare-bones, if you ask
    me, though quality is definately good, @ $220 price is just right
    -vhelp 4047
    my YouTube videos
  18. Member
    Originally Posted by budz
    PIONEER 220-S
    Really nice machine. Too bad I replaced it with a 640hs. Had to have a HDD and ran out of video inputs on my Receiver.
    But I think I'll unhook the Laser Disc since it now gets very little use.
    Anyway I find these Pioneers really good and easy to learn. And the price I got the 640hs for was mind blowing.
    NL
  19. Member mattypj's Avatar
    I just use my Pc with a built in hd tuner and capture card!
    Works great!
    Live lightly, think deeply.
  20. 5 PVR's, all with Hauppauge cards, sharing common recording folders on the LAN.
    Cheers, Jim
    My DVDLab Guides
  21. Member yoda313's Avatar
    Interesting, its a statistical deadheat between liteon, panasonic, and pioneer.
    And that 18% use a pc/dvr instead of a dvd recorder.
    It would be interesting to get an accurate read of how many people use both.
  22. I'm a MEGA Super Moderator Baldrick's Avatar
    maybe next poll...
  23. 2 Toshiba D-R4s, never touch anything else again. If they die I'll be on ebay replacing them. Still have a Panasonic E-10 that might outlive me.
  24. Panasonic 8)
  25. Member kjvsword's Avatar
    ILO DVDR04 and ILO DVDR04 and a ILODVDR04
    AV1611TRIEDTRUE
  26. Member
    Pioneer 220-s here. Excellent machine.
    Yeah, I'm probably nuts... But what the hell. Nobody's perfect.
  27. Member lacywest's Avatar
    From Directv HR10 to Panasonic EH50 ... works very nicely
  28. I record with a DVD Recorder connected for national channels.
    From a satellite card for other channels.
  29. Man of Steel freebird73717's Avatar
    Since this thread has already been resurrected from the dead I'll post also.
    Directv tivo (no transfer capabilities) and a ati all in wonder card.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
  30. Member DVWannaB's Avatar
    JVC DMR-30
    Pioneer 520H, 650
    Sony RD-HX710
    Toshiba DR-4, XS-52, XS-54, XS-55
    Panasonic ES37
    Also used in past:
    ReplayTV, TiVo, ProVideo PCI card, Hauppauge 250 PCI. PCI cards sold on ebay and RplayTV and TiVo going up soon.
  1. Replies: 4
    Last Post: 10th Sep 2010, 15:14
  2. Standalone DVD recorder to youtube
    By duckvids in forum Newbie / General discussions
    Last Post: 10th Jul 2009, 17:46
  3. Make old parts of PC act like a DVD standalone Recorder
    By SatStorm in forum Media Center PC / MediaCenters
    Last Post: 21st Nov 2008, 02:41
  4. Problem ripping standalone DVD recorder disc
    By mojo in forum DVD Ripping
    Last Post: 28th Oct 2008, 23:33
  5. DVD Recorder Standalone
    By ebob in forum Authoring (DVD)
    Last Post: 1st Jun 2007, 11:40
