VideoHelp.com Forum
    I've downloaded an anime series which I want to burn to be played on a DVD player in widescreen.
    The series is in AVI format and the resolution is at 640x360 (already 16:9). I've been using the program [Boilsoft AVI to VCD/SVCD/DVD Converter] to convert the AVI into MPEG. I burnt the converted videos with Nero 6.
    When I watched the videos on the DVD player with a 4:3 TV, it is not letter-boxed so the sides are cut off. I've tested it on multiple DVD players, but they all give the same result.
    Converting the videos takes so long... so I need some help instead of wasting my time and DVDs testing.
    I'm not sure what I'm doing wrong, if anyone can help or recommend a better program to convert videos which may solve my problem and give me step-by-step instructions on how to convert with that program I would be very grateful.
  3. Always Watching guns1inger's Avatar
    ConvertXtoDVD is the simplest solution by far. The only caveat is if the anime is fan-subbed. If so, there is a good chance the subs do not observe safe zones, and will get cut off at the edges. if this happens then you will have to look at a combination of FitCD, avisynth and a standalone encoder. Do a search in these forums for Overscan and FitCD for more details.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    @zephi
    You can also use my tool DIKO (which is Freeware). Just remember to change the configuration to get widescreen output.
    VMesquita
    My Tools:
    DIKO
    FreeEnc: AVS->MPEG2 Encoder
    Get them here: http://www.vmesquita.com
  1. Problem converting dvd to avi or mpeg
    By JARRE2000 in forum Newbie / General discussions
    Last Post: 30th Nov 2010, 15:43
  2. Widescreen aspect problem converting avi to dvd
    By spiritgumm in forum Video Conversion
    Last Post: 10th Apr 2010, 13:14
  3. converting .rm to mpeg, avi using eo video problem!!
    By convertme in forum Newbie / General discussions
    Last Post: 14th Sep 2008, 00:37
  4. Problem converting avi to dvd(mpeg)
    By Wackster in forum Video Conversion
    Last Post: 14th Jan 2008, 22:49
  5. Problem when converting DV AVI files to MPEG
    By MI6 in forum Video Conversion
    Last Post: 29th Jul 2007, 14:34
