VideoHelp.com Forum
  1. So i have been using unlead dvd workshop for a while but im sick of it working off and on... basically sometimes the dvds work and sometimes they just stick in the middle of the chapters or movie. What is the best authoring program out right now thats easy to use and have a lot of funtionality????
  2. Mod Neophyte Super Moderator redwudz's Avatar
    DVD Lab Pro is probably one of the better ones. If you need simple menus and ease of use, TMPGEnc DVD Author.
  3. Always Watching guns1inger's Avatar
    Have you kept your version up to date ? There have been a couple of patch releases to DVDWS 2.
    Are you sure it isn't an asset problem ? 9 times out of 10 the problem lies in the encoding or other problem with the assets, not the authoring. There is no point changing authoring software unless you are sure it is the problem.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Originally Posted by guns1inger
    what do you mean asset problem???? and if its a encoding problem then that mean it may be dvd workshop when it encodes everything at the end. I will look on their site and see about the patches though.
  5. Always Watching guns1inger's Avatar
    If your assets are DVD compliant and will fit on the disc, then DVDWS should not re-encode them.
  6. well i use vegas to edit i also capture my video in mpeg 2 format
  1. program
    By maxone71 in forum SVCD2DVD & VOB2MPG
    Last Post: 30th Oct 2011, 05:23
  2. What's the name a program? unkown program
    By Andrey81 in forum Subtitle
    Last Post: 26th Jan 2011, 12:04
  3. Replies: 1
    Last Post: 21st Sep 2009, 08:42
  4. which program?
    By MONSTERTITO in forum Authoring (DVD)
    Last Post: 1st Oct 2008, 12:30
  5. Replies: 6
    Last Post: 10th Jul 2007, 06:05
