Results 1 to 19 of 19
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hey everyone, i recently got this computer game and there are complete songs that play in the background while you play. i liked some of the songs and checked in the game's data folders and found these audio files, however they were in a MUS file format. i was wondering if there was a way that i could convert this audio to MP3, or any other audio for that matter. please assist. thanks.
    skip
    Wow! You got shocks, pegs... LUCKY!
  2. Member Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Have you tried to open the mus file with Goldwave or Audacity? If you can send me a small mus file I can look at what I have and see if they will convert the file.
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    sure here ive hosted one of the files. im gonna try to open them with the suggested apps.
    click here for the hosted file
  4. Member Bodyslide's Avatar
    Feb 2002
    Audacity opened it with no issues, I then converted it to MP3
    rakim_megamix.mp3
  5. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    yeah audacity doesnt worked for some reason for me but i tried adobe audition and it worked like a charm. thanks i guess the problem is solved thanks man.
    skip
    Nov 2002
    You don't need to convert it. Just change the extension to mp3. That's what GSpot reads it as.
    MPEG-2 Layer 3 96 kbps 22050 hz
    I thought it was a midi clone from all I could find on Google but it seems it's just an mp3 renamed.
  7. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    It depends on the game. '.mus' is a rather generic extension, IMHO - some games like the original Doom used 'mus' format music, which I think was indeed a variation on MIDI.
  8. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    This is not really video related. Moving you to the Computer Forum.
  9. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    thanks for the tip, there were like 30 tracks and it would have taken forever to run them thru audition, so i just renamed them and it worked fine. thanks.
    Nov 2002
    You're welcome.
    There is a program called ProperyPlus that will let you highlite all of a certain file type in a folder and change the extension of them all at once. It's alot easier than changing them one at a time.
  11. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    thanks very much it will definately be a big help. im very thankful. take care.
    i just googled it and i cant find it anywhere, do u perhaps have a download link? thanks again.
  12. Member Bodyslide's Avatar
    Feb 2002
    property plus is the name of the application, but I can't find it either. I will keep looking and post a link back here...
  13. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    you could also open a dos prompt (command line) and type
    ren *.mus *.mp3
  14. Member mstone321's Avatar
    Jan 2002
    Left Coast, Canada
    DOS? What's DOS? Just kidding. I still do DOs all the time for certain things.
    A good renamer (does a lot more than extensions) is CKRename and it's easy to find.
    Nov 2002
    I couldn't find a download site that still carries it but I did find a workable download link.
    http://homepage.ntlworld.com/pesala/clipboard/pplus165.exe
    Nov 2002
    I also found this site that has all kinds of freeware.
    http://pricelessware.org/thelist/index.htm
    but the link for PPlus doesn't work.
  17. Member Bodyslide's Avatar
    Feb 2002
  18. Member
    Nov 2002
    BTW, PropertyPlus integrates itself into explorer so when you right click on a file, you not only get the normal Properties but also a Properties Plus.
    It's just like Properies but gives you the capabilities of changing extensions and timestamps.
    Nov 2002
    Here is the Link from PC World.
    That's the first place I went and a search turned up nothing but rental property software.
    That's probably where I originally downloaded it from years ago when I subscribed to the magazine.
