Hello people
I got a Targa MP3/Video player - MP3 H2010 ( if needed I’ll post the link to the machine)
That only plays Motion JPEG video.
I’ve ask them for help but the answer was :
“The supported formats are indeed Motion JPEG AVI, Motion JPEG MOV. Mpeg4 is not supported … go to w w w . codecs . com.”
Not very elucidative.
So I searched your forum for help but didn’t find anything like this question:
How to convert video files ( for instance Avi files) to Motion JPEG files, to play them in the player.
Many thanks in advance.
Results 1 to 19 of 19
Install for example PICVideo MJPEG
Convert with Virtualdub,
open the video
select video->compression and choose the picvideo mjpeg
select audio->compression and choose mp3 if it is supported
last file->save avi.
you may to have resize to lower resolution also, under video->filters in virtualdub.
Or try SUPER, it may have some mjpeg codec settings also. -
Many thanks for the tutorial,
Gona try it
If got problems I'll get to U again. -
Well here I am again,
After almost 1 day of work ( the problem is that my daughter and me are in different fiscal places & testing over Inet so there are lots of dl/ul time lost) The basted doesn’t recognize the movie test.
Here the History:
I got the codec PICVideo MJPEG and Virtualdub,
Installed both
And use Vdub to convert ( as you told me) resize and cut the MPG clip to the AVI
Finally I check with Gspot that it was all right, and it seem ok
After uploading it to my daughter she told me that the basted targa says that the video type is not compatible
I have uploaded the files ( Initial mpg and final avi) to rapidshare
If anyone can give a look to see if I’m missing something I appreciate
Thanks to every one already involved.
Link:
Code:http://rapidshare.de/files/25210153/StupidTarga.zip.html
A sample of a working file to compare would probably be more useful than the source mpg.
Now it’s my last chance of Net over weekend, By Monday Ill try to upload a working small clip.
(I'll use a digital camera)
Best weekend to all you !!!!!!!!!!!!!!!!!!!!!!!! -
As celtic_druid suggest I’ve upload a small movie (taken by a camera) that works on the Targa machine
Its image is relay bad but doesn’t care because was taken from TV just for example.
The link is
Note1: both files, first posted and this one now are really small.Code:http://rapidshare.de/files/25438211/PICT0700.AVI.html
Note2 : the converted file (El_crack_de_la_oficina1.avi) only shows the first frame and the player stop responding and have to restart it.
Thanks for helping -
I have been developping an application working with mencoder to convert videos to many different formats and i have just included an mjpeg output profile, the program is Movie Library ++ http://www.mandeldev.co.uk/EN/downloads.html and it will convert almost any video to an avi using mjpeg codec and mp3 sound with the resolution and bitrate you choose so try it out let me know if it works.
djagt3: PLEASE stop dig up old topics. We know that you have a new tool out now.
I found http://fixounet.free.fr/avidemux/ to be easiest. I got a working mjpeg file on my first try. Now I have video on my Sony Digital Frame DPF-D820
here is a short tutorial on the software mentioned above: http://www.ehow.com/how_5539563_convert-avi-motion-jpeg.html
video/audio quality is low, but for our purposes we just need to find out if your Sony Digital Frame DPF-D820 frame can playback mjpeg. so here goes:
https://docs.google.com/leaf?id=0ByVrqkwNw_qbMGFmOGU1NjktMWU5Zi00OTIwLWE0NGUtYzQ2OWVkZjk1YTVh&hl=en
or just click Download (109 MB)
1. download
2. copy to sd card or usb drive
3. video should just playback once u connect the media with the file above to your Sony Digital Frame DPF-D820. -
I am having difficulty converting to the M-JPEG format that my Sony DPF-D830 photo frame can read. I have downloaded the jump video recommended on this thread above and can play it OK. But when I convert an AVI file from my Canon camera using AVIDEMUX the photoframe does not recognise it - it says there are no files on the USB stick.
Should be more versatile one...
Code:@ffmpeg.exe -threads %NUMBER_OF_PROCESSORS%*1.5 -i %1 -vf "scale='if(gt(a,4/3),640,-1)':'if(gt(a,4/3),-1,480)':sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp,pad=640:480:(ow-iw)/2:0" -c:v mjpeg -b:v 768.0k -dc 8 -af "aformat=sample_fmts=fltp,pan=stereo|FL < FL + 1.414FC + .5BL + .5SL + 0.25LFE|FR < FR + 1.414FC + .5BR + .5SR + 0.25LFE,aresample=resampler=soxr:osr=44100:cutoff=0.990,aformat=sample_fmts=fltp:channel_layouts=stereo" -c:a libmp3lame -ar 44100 -b:a 128.0k -f avi %1.avi
converting to mjpeg
By GodsOtherHand in forum Video ConversionReplies: 1Last Post: 7th Apr 2011, 15:03 -
MJPEG export
By vizion in forum ffmpegX general discussionReplies: 2Last Post: 9th Feb 2011, 12:52 -
Convert 4:3 PICVideo mjpeg to 16:9 DV w/o losing clarity
By brassplyer in forum EditingReplies: 12Last Post: 5th Jan 2011, 01:13 -
how to batch convert camera video (MJPEG) to xvid?
By shun in forum Video ConversionReplies: 1Last Post: 2nd Feb 2010, 15:10 -
Convert AVI to Mjpeg-II or other format
By hemang in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 07:23
