VideoHelp.com Forum
Results 1 to 10 of 10
    Hello,
    I'm just wondering if anyone has had any success using the Delogo filter 1.3.2 (used with virtual dub) with Sony Vegas (via WAX 2.0). I'm able to load the filter onto the media track and go through the configuration options, but when i'm finished with the configurations, the video is left untouched. Also, every works fine when I use the filter in virtual dub.
    Let me know what you think. Thanks.
  2. Member Cunhambebe's Avatar
    Frameserve from VD to Vegas? Can you make VD frameserve?
  3. Член BJ_M's Avatar
    the filter doesnt work via wax , you have to frame serve to vegas via the vfapi interface instead - or render out of VD first ...
    note that have had some weird results with the vfapi wrapper - with HD 1080i files .. the time code gets messed up when used with tmpgenc as the server (source are blackmagic 10bit QT files)
    Thanks for the response. I'm gonna give things a shot (frameserving). I also stumbled upon another filter which i'm going to try.
  5. Member Cunhambebe's Avatar
    I definitely can't make VD frameserve...I 've already tried everything :P
  6. Always Watching guns1inger's Avatar
    Have you run the AuxSetup.exe file in the VDub root folder ? This preps the system to allow VDub to frameserve.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  7. Member Cunhambebe's Avatar
    Yes, I have I've also tried VFAPI
    Result = absolutely nothing!
  8. Always Watching guns1inger's Avatar
    OK. So you load up the avi, and go File->Start frame server.
    Do you get the dialog to give the FS a name ?
    If so, you click on the Start button and get asked to save a signpost file. Do you get this ?
    If so, you save the file, and the FS status dialog should open. Do you get this ?
    If you have got this far, you should be able to open the signpost file in your encoder and see the output from the frameserver (ignore the vfapi side of things for the moment, let's just get the FS working)
    Just to let you know, I found another Vdub delogo filter THAT WORKS with Vegas and Wax. It's called "Region Remove" and it works well.
    I'm not exactly sure where i got it from but if you do search with it's name, i'm sure you will find it.
  10. Member Cunhambebe's Avatar
    guns1inger
    Thanks so much for replying - I'm not highjacking the post
    -Yes, Sir.
    -Yes, sure.
    -Yes, I do...
    -When I go to save the file, nothing is saved. That's why I can't open it with the encoder. Anyway, I'll try it again - thanks again for your help.
    Cheers,
    Mark
  1. Removing Logos using DeLogo vdub filter
    By Matt D in forum Editing
    Last Post: 19th Oct 2011, 10:57
  2. How do I make a filter for VDub
    By blaze01 in forum Newbie / General discussions
    Last Post: 4th Mar 2008, 16:16
  3. Merits of the delogo filter
    By lordsmurf in forum Restoration
    Last Post: 10th Dec 2007, 06:09
  4. ACDsee Filter&VDUB
    By mv0930 in forum Newbie / General discussions
    Last Post: 4th Sep 2007, 12:27
  5. Vdub Filter Chain
    By christopheramos in forum Video Conversion
    Last Post: 3rd Sep 2007, 07:57
