VideoHelp.com Forum
    I have just built a multimedia PC for my bedroom and are in the process of converting my dvd's to avi so i can have them all on my machine. I'm using dvd decrypter to rip the dvd's and have the settings
    File Mode-Selected files-main movie
    File Mode-File Splitting-None
    applied and was hoping to use AutoGK to convert them to avi but the audio is always out of sync, does anyone know why this is? Thanks.
  2. Hi-
    You should be decrypting with DVD Decrypter in IFO Mode, and not File Mode. If that doesn't fix the problem, then maybe you're encoding newer movies with the newer protections, and you'll have to take steps to remove it and clean up the files. But I'd first suggest trying IFO Mode.
    Thanks manono but that didn't help, the DVD i trying to back up is Madagascar, any other suggestions?
    Thanks.
  4. VH Veteran jimmalenko's Avatar
    You should rip in IFO mode so that you can load the associated IFO file. This IFO file contains details of any audio offsets and AutoGK can apply those offsets, resulting in an in-synch rip.
    If in doubt, Google it.
  5. Member Moonstomp's Avatar
    Hi,
    Maybe you should try a different encoder - I haven't used it but SUPER has been getting good reviews.
    Moonstomp
    Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
  6. Member hech54's Avatar
    Before you encode...run the material through FixVTS.
  7. Hi-
    ...any other suggestions?
    Sure, we're always full of bright ideas, worth about what you pay for them. Madagascar is an ArccOS protected disc, something I speculated about in my first reply. I haven't tried it yet, but all reports say that RipIt4Me can handle about anything you can throw at it. The newest version has a Movie-Only Mode, I believe. So, my next suggestion is to run the DVD through RipIt4Me in Movie mode. If worse comes to worst, you can always adjust the delay to get the audio back in synch. It would be easier than decrypting and running the whole thing through AutoGK again, but it'll be a good learning experience that will hold you in good stead for the future.
    http://www.videohelp.com/guides.php?guideid=911#911
    Edit: hech54's suggestion is also a good one. RipIt4Me does the same thing to the DVDs with those newfangled copy protections.
  8. Hi, I use DVD Decrypter and AutoGK all the time and have no sync problems. I adjusted the setting according to the directions at this url. I hope it works for you too.
    http://www.rita.lt/guides/AutoGK_DVDtoAVI.htm
  1. Replies: 20
    Last Post: 25th Apr 2010, 03:01
  2. Replies: 7
    Last Post: 7th Dec 2009, 23:06
  3. Audio/video out of sync with autogk
    By vain in forum Newbie / General discussions
    Last Post: 30th Mar 2009, 18:05
  4. autogk, audio out of sync
    By Disa in forum DVD Ripping
    Last Post: 30th May 2007, 15:03
  5. autoGK subtitle out-of-sync with audio?
    By cristolin in forum Subtitle
    Last Post: 16th May 2007, 00:14
