VideoHelp.com Forum
Results 1 to 10 of 10
    Are they not downloading correctly, or is it not recognizing them? Every time I launch ffmpegx, it asks me to download and install the three binaries. I just copy and paste the url it gives me and select the appropriate mirror, but it never seems to work. Advice?
    Also, I don't know if this is a related problem, but after I hit the encode button, a message comes up asking me to locate Terminal.app with a list of everything on my computer. I've basically got two problems that are preventing me from using ffmpegx; any help?
    I am having the same problem, is there a solution?
    Me three!
  4. The binaries should be the following size or they will not be recognized:
    mpeg2enc = 501480 bytes
    mplayer = 15869784 bytes
    mencoder =16655780 bytes
    Aren't you guys using non-Universal version of UNIX encoders? You cannot use with the latest version of ffmpegX old ones that were working with, for example, v.0.099u. You can download right ones (in Universal binaries) at http://seo.mhouse-j.com/web_hosting/...s/ffmpegx.html
    FYI. tbluwater's binaries solved the issue for me.
    Good for you.
    By the way, my login name is tbluewater as in Tom Bluewater.
    Hey! Thanks man.
    We have moved our ffmpegX support page to this address.
  10. tbluewater's binaries worked for me too...Thanks!
  1. Ffmpegx missing codec components?
    By plugues in forum ffmpegX general discussion
    Last Post: 10th Oct 2009, 11:51
  2. Unable to download ffmpegx
    By benjavi in forum ffmpegX general discussion
    Last Post: 1st Nov 2008, 23:58
  3. ffmpegx wont download
    By wendyhouse in forum ffmpegX general discussion
    Last Post: 14th Nov 2007, 06:31
  4. Replies: 4
    Last Post: 7th Oct 2007, 13:12
  5. Ffmpegx suddenly won't launch at all
    By epa1nter in forum ffmpegX general discussion
    Last Post: 9th Jul 2007, 21:13
