Every time that I launch ffmpegX, it opens the component install dialog.
ffmpegX version: 0.0.9w (r5)
Mac OS X 10.4.6 / Dual G5 2 GHz (2003-06)
Boot Volume name: G5a
I've double-checked that I've downloaded the correct versions.
(even going so far as to download from both the links in the install dialog, and from the web site then `diff`ing the binaries!)
Is it okay to leave the binary named "mpeg2enc.intel" on my G5 Mac? Should I perhaps have renamed the extracted file as "mpeg2enc"?
I've also tried launching after deleting all traces that I could find of ffmpegX:
Code:rm -rf /Applications/ffmpegX* "/Library/Application Support"/ffmpegX* ~/.mplayer* ~/Library/Preferences/mplayer.plist
Looking at ffmpegX's application support dir from the command line, it looks a bit suspicious:
...some items are owned by root, an others by ddd (my user account that has admin privilges)
...also suspicious, there are three distinct user+group combinations of file ownership in that directory: root+admin, ddd+staff, and ddd+admin.Code:$ ls -al /Library/Application\ Support/ffmpegX total 69312 drwxrwxrwx 18 root admin 612 Jul 3 22:46 . drwxrwxr-x 25 root admin 850 Jul 3 22:46 .. -rw-r--r-- 1 ddd staff 6148 Jul 17 2004 .DS_Store -rwxr-xr-x 1 ddd admin 281028 May 15 2004 gocr -rw-r--r-- 1 ddd admin 500 May 15 2004 gocrfilter_en.sed -rw-r--r-- 1 ddd admin 361 May 15 2004 gocrfilter_fr.sed -rw-r--r-- 1 ddd admin 271 May 15 2004 gocrfilter_nl.sed -rw-r--r-- 1 ddd admin 67 May 15 2004 gocrfilter_none.sed -rwxr-xr-x 1 root admin 16655780 Jul 3 22:46 mencoder -rwxr-xr-x 1 ddd staff 244832 May 15 2004 mp2enc -rwxr-xr-x 1 root admin 501480 Jul 3 22:46 mpeg2enc -rwxr-xr-x 1 root admin 15869784 Jul 3 22:46 mplayer -rwxr-xr-x 1 ddd admin 22596 May 15 2004 subtitle2pgm -rwxr-xr-x 1 ddd staff 286168 Jul 17 2004 tcextract -rwxr-xr-x 1 ddd staff 589400 May 15 2004 vcdxbuild -rwxr-xr-x 1 ddd staff 568908 May 15 2004 vcdxgen -rwxr-xr-x 1 ddd staff 113352 May 15 2004 yuvdenoise -rwxr-xr-x 1 ddd staff 314968 May 15 2004 yuvscaler
Any help greatly appreciated,
./ddd
Sorry forgot to mention that after I complete the "component self-installer" the application works normally.
However, if I CANCEL the "component self-installer", the the application works normally then too!
./ddd
On my side of the wire, ffmpegX doesn't ask for binaries repeatedly, and the permissions in my Application Support folder look very similar with respect to the three binaries:
Something must be different, though?!?Code:$ ls -al /Library/Application\ Support/ffmpegX total 69312 drwxrwxrwx 20 root admin 680 May 2 00:48 . drwxrwxr-x 22 root admin 748 Jul 3 14:59 .. -rw-r--r-- 1 case staff 6148 Jul 3 15:12 .DS_Store drwxr-xr-x 42 case admin 1428 Apr 30 04:02 db -rwxr-xr-x 1 case admin 281028 May 15 2004 gocr -rw-r--r-- 1 case admin 500 May 15 2004 gocrfilter_en.sed -rw-r--r-- 1 case admin 361 May 15 2004 gocrfilter_fr.sed -rw-r--r-- 1 case admin 271 May 15 2004 gocrfilter_nl.sed -rw-r--r-- 1 case admin 67 May 15 2004 gocrfilter_none.sed -rwxr-xr-x 1 root admin 16655780 Apr 30 03:06 mencoder -rwxr-xr-x 1 case staff 244832 May 15 2004 mp2enc -rwxr-xr-x 1 root admin 501480 May 2 00:48 mpeg2enc -rwxr-xr-x 1 root admin 15869784 Apr 30 03:06 mplayer drwxr-xr-x 50 case admin 1700 Mar 10 00:23 reallib -rwxr-xr-x 1 case admin 22596 May 15 2004 subtitle2pgm -rwxr-xr-x 1 case staff 286168 Jul 18 2004 tcextract -rwxr-xr-x 1 case staff 589400 May 15 2004 vcdxbuild -rwxr-xr-x 1 case staff 568908 May 15 2004 vcdxgen -rwxr-xr-x 1 case staff 113352 May 15 2004 yuvdenoise -rwxr-xr-x 1 case staff 314968 May 15 2004 yuvscaler
Case:
Yes I agree that our application support dir permissions are essentially identical, so I think we can rule that out as a potential cause.
Thanks,
./ddd
(Sorry about the accidental re-post of (most of) the original
- I've nuked it)
Despite the component self-installer warnings, if I compare the "application support" copy of each of the binaries to the latest downloaded ones, they are all the same:
So for the meantime I'll just get used to hitting cancel on start-up ;-)Code:$ cd ~/download/ffmpegX-0.9w-tools/ $ diff "/Library/Application Support"/ffmpegX/mpeg2enc mpeg2enc.intel $ diff "/Library/Application Support"/ffmpegX/mplayer mplayer $ diff "/Library/Application Support"/ffmpegX/mencoder mencoder
All the best,
./ddd
With the content checked, it may be worth checking permissions on the ffmpegX folder itself:
Code:ls -al /Library/Application\ Support ... drwxrwxrwx 20 root admin 680 May 2 00:48 ffmpegX ...
Yep, same group, owner & permissions (root, admin, 777).
(Though as an old school unix geek, I find it a little distirbing that the directory is world-writable, (especially considering that it houses executables))
Wants me to install binaries every time I launch!
By Navstar in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2010, 05:27 -
Ffmpegx missing codec components?
By plugues in forum ffmpegX general discussionReplies: 5Last Post: 10th Oct 2009, 11:51 -
Can not install mpeg components
By franks65 in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2008, 09:57 -
Missing Codec(s) ... How to find/install/use?
By CaptainChaos in forum Video ConversionReplies: 7Last Post: 18th Oct 2007, 02:47 -
why does ffmpegX want to self install the components every time i open it u
By jboyd in forum ffmpegX general discussionReplies: 4Last Post: 7th Oct 2007, 13:12
