VideoHelp.com Forum
    I have several seperate .ts files that I need to join into one .ts I did try TSJoiner but the output was jerky play.
    I tried looking around but found nothing.Maybe I didnt search right?
    I will be using the single file for encoding to DVD and another for small XviD later.
    I just need the one file for now unless I can import all into something and output a DVD and XviD
    Thanks in advance.
  2. Член BJ_M's Avatar
    mpeg2vcr will work ... as will the dos copy command
    What do you mean by this.From the software you listed or going to my windows CMD ?
  4. Член BJ_M's Avatar
    windows CMD
    copy /B filea.ts+fileb.ts+filec.ts newfile.ts /B
  5. Member Soopafresh's Avatar
    And this app will combine and split Transport Streams quite nicely.
    http://www.ffprojects.net/
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Hm, tssplitter is dot net bloatware, and HDTVtompeg2 sounds like its a converter.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    HDTVtompeg2 doesn't reconvert, it just joins. But it will probably just work with mpeg2 streams.
    You can also use tsmuxer.
  1. Combine two transport streams.
    By Deadeditor in forum Newbie / General discussions
    Last Post: 13th Apr 2011, 08:12
  2. Seeking in Transport Streams(.TS)
    By deepp in forum Programming
    Last Post: 15th Jul 2010, 16:00
  3. NO LFE channel in TS transport streams ?
    By s1lenc0r in forum Video Conversion
    Last Post: 17th Apr 2010, 07:02
  4. Converting Transport Streams to AVI
    By RedPenguin in forum Video Conversion
    Last Post: 14th Apr 2009, 22:56
  5. European transport streams
    By branch in forum DVB / HDTV
    Last Post: 27th Mar 2008, 03:50
