Like when i try to use Nerovision to do menu, It re-encode the .vob, which is annoying because I have to convert the video format to .vob(Which takes awhile) and then I have to reconvert .vob to the same format just to add the menu.
Is there like a program just for making menu and then you can just burn the .vob file with the menu files.
tda, select add dvd video and choose the vob file folder.
I try using TDA and made the menu, but on the output, when I click begin output it seems that its re-encoding the video. And taking over 30 minutes, I just want the menu alone with TDA.
How to add 5.1 (6 channels) to a VOB file
By samjo511 in forum AudioReplies: 17Last Post: 27th Jul 2010, 22:49 -
Keep original DVD menu, add new movie file
By Booklet in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2009, 16:21 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36 -
How to add AC3 file to already existing menu
By chrishallowell in forum Authoring (DVD)Replies: 11Last Post: 14th Sep 2007, 12:32 -
Add Dolby Digital to an existing VOB file
By ianwuk in forum AudioReplies: 4Last Post: 13th Jul 2007, 10:09
Statistics
Newest guides
Latest tool updates
New media comments
