VideoHelp.com Forum
Page 7 of 7
FirstFirst ... 5 6 7
Results 181 to 183 of 183
  1. Member bithead9's Avatar
    Unless I am loosing my mind, my post at time index: 27th Feb 2011 18:42 said to use exacly that link and there are several DOWNLOAD buttons big as day. You pick the one for your USA unit ILO, LITEON etc. Good luck with your conversion to 512GB and the DVD drive repalcement. Its lots of fun to play with these units.
  2. Actually, Batchman didn't particularly want to use any particular firmware update, but just wanted to find out which one(s) I would likely need to use. Between the three of you, it's pretty well established! Thanks to all three of you!
    Looking forward to this!
  3. Hard drive arrived, installed it, formatted fine, everything is wonderful.
    Still had to install it upside-down ... if I had tried to install it right-side-up, it probably wouldn't have fit in the case ... I would have needed new cables because the ide cable and the power cable were both too short to swap places ... and even without those two problems, the bridge would not have fit.
    Thanks all for your help ... my ilo is fully back in business, and much more of a powerhouse!
  1. Liteon LVW-5045 replace DVD drive, project started...
    By dainova in forum DVD & Blu-ray Recorders
    Last Post: 5th Apr 2011, 06:04
  2. LITEON LVW-5045 cannot read DVD-R disks
    By elfie-gow in forum DVD & Blu-ray Recorders
    Last Post: 29th Jan 2011, 16:58
  3. lite-on LVW-5045
    By pmitch in forum DVD & Blu-ray Recorders
    Last Post: 18th Mar 2009, 03:44
  4. Liteon 5045 Hard Drive Recoring Transfer
    By allibg5 in forum DVD & Blu-ray Recorders
    Last Post: 25th Feb 2009, 14:43
  5. LiteOn Lvw-5045 (UK - English)
    By cubud in forum DVD & Blu-ray Recorders
    Last Post: 10th Jun 2007, 14:05
