Ok i think there might be an issue with ffmpeg inside of the Latest 2.1 version. I updated from 2.0 to 2.1 the day before yeterday and never had a problem before with 2.0 . All of a sudden the First movie i tried to convert and burn started having problems i tried doing the same movie 4 times and always had the same ffmpeg issue btw i monitored my temps and never broke over 55c on CPU and 30c on MB on all 4 attempts. So today after work i uninstalled 2.1 and reinstalled 2.0 and it worked perfect with the same movie and process that i used with the 4 prior attempts. So i thought i should post this stuff for you to look at cause not sure if this turning out to be more of a problem than with just one person and i love this program but about cried when it started to fail me "which is a first btw".
Below is the error message followed by the Log with error for 2.1 and then the 2.0 convert/burn which had no problem at all i can provide some nice screen shots also if needed.
Version: SVCD2DVD 2.1
Build: 2.1.2308.33338
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.x3b9d134dac76e 484(xece14591aa1abb99
x50afe96f7df19242, xcbd1127f90d7945f x3146d638ec378671)
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.1
Version: 2.1.2308.33338
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
Executable size: 2.85 MB
Executable size in bytes: 2998355
Executable CreationTime: 4/27/2006 11:33:02 PM
Executable LastWriteTime: 6/18/2006 6:03:01 PM
Executable LastAccessTime: 6/28/2006 10:12:31 PM
************************* Operating System *************************
Operating System: Microsoft Windows XP Home Edition
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 1
Local: 0409
Total Physical Memory: 0.99 GB
Free Physical Memory: 587 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: ASUSTeK Computer INC.
Computer Model: A7N8X-X
System Type: X86-based PC
Computer Name: MAINRIG
DomainRole:
Number Of Processors: 1
User Name: MAINRIG\
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) XP 2800+
Description: x86 Family 6 Model 10 Stepping 0
CPU Speed: 2.088GHz
CPU FSB: 166MHz
L2 Cache Size: 512 bytes
***************************** Time Zone ****************************
Time Zone: (GMT-05:00) Eastern Time (US & Canada)
****************************** VIDEO *******************************
Processor: RADEON 9200 AGP (0x5961)
Mode: 1280 x 1024 x 4294967296 colors
Video Ram: 128 MB
Status: OK
Name: RADEON 9200 - Secondary
Processor: RADEON 9200 Secondary AGP (0x5941)
Mode:
Video Ram: 128 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 71.4 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 36.1 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="6/28/2006 6:16:38 PM" Filename="NONE"><AssetSet><Asset
ID="1a02ed01-80ea-4e27-8c44-c377ae7c5a92" Path="C:\Movies\Click" Filename="mvn-clickts01.avi"
/><Asset ID="2402d150-459f-41f8-93ee-fa41be61727d" Path="C:\Movies\Click"
Filename="mvn-clickts02.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie"
PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49"
FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title
Name="mvn-clickts01.avi" AssetID="1a02ed01-80ea-4e27-8c44-c377ae7c5a92" MplexOffset="0"
/><Title Name="mvn-clickts02.avi" AssetID="2402d150-459f-41f8-93ee-fa41be61727d"
MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681"
ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True"
BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2\default.jpg" AudioPath=""
/></DVDStructure><Settings><General InitialAssetFolder="D:\Downloads\SVCD Movies"
InitialDVDFolder="D:\Downloads\SVCD Movies" InitialProjectFolder="D:\Downloads\SVCD Movies"
InitialMenuBackgroundFolder="" DeleteS2DFiles="True" UseDVDShrink="False" /><Menu
AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath=""
TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All"
Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process
AudioEncoding="mpa" Chapters="Every 30 mins" SkipMPA48="False" SkipAC3="True" PanSan="False"
MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS"
NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix=""
TVOverscanPixels="0" UseThreads="True" /><Program BINExtraction="vcdxrip" VCDGearFIX="False"
FastAudioEncode="True" /><Burning BurningMethod="DVD Decrypter" DVDDrive="SONY DVD RW
DRU-710A " NeroWriteSpeed="Max" Eject="True" HighDVDCompat="False" VerifyDVD="False"
DVDDecrypterPath="C:\Program Files\DVD Decrypter\dvddecrypter.exe" DVDDErase="True"
DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 702 MB
file=C:\Movies\Click\mvn-clickts01.avi
FormatName=avi
Num_Frames=71250
DurationInSecs=2850
Duration=00:47:30.0
VideoCodec=mpeg4
Width=704
Height=416
Standard=PAL
BitRate=2069
AudioStreamCount=1
Audio1StreamID=[0x1]
Audio1SampleRate=44100
Audio1Codec=mp3
Audio1BitRate=128
Audio1Channels=2
AVI2MPG: 5752kbs Full-D1
18:16:38: Looking for AVI PAR...
Pass 1/1: Processing mvn-clickts01.avi
18:16:39: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
18:16:39: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug
--enable-pthreads
18:16:39: libavutil version: 49.0.0
18:16:39: libavcodec version: 51.4.0
18:16:39: libavformat version: 50.2.1
18:16:39: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
18:16:39: Input #0, avi, from 'C:\Movies\Click\mvn-clickts01.avi':
18:16:39: Duration: 00:47:30.0, start: 0.000000, bitrate: 2069 kb/s
18:16:39: Stream #0.0, 25.00 fps(r): Video: mpeg4, yuv420p, 704x416
18:16:39: Output #0, dvd, to 'C:\Movies\Click\mvn-clickts01_S2D.mpg':
18:16:39: Stream #0.0, 25.00 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 5752
kb/s
18:16:39: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
18:16:39: Stream mapping:
18:16:39: Stream #0.0 -> #0.0
18:16:39: Stream #0.1 -> #0.1
19:00:07: video:1998480kB audio:77929kB global headers:0kB muxing overhead 1.903351%
19:00:07: AVI2MPG: done.
PAL->NTSC: demuxing mvn-clickts01_S2D.mpg
19:00:08: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
19:00:08: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug
--enable-pthreads
19:00:08: libavutil version: 49.0.0
19:00:08: libavcodec version: 51.4.0
19:00:08: libavformat version: 50.2.1
19:00:08: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
19:00:08: Input #0, mpeg, from 'C:\Movies\Click\mvn-clickts01_S2DPAL.mpg':
19:00:08: Duration: 00:47:29.6, start: 0.500000, bitrate: 6082 kb/s
19:00:08: Stream #0.0[0x1e0], 25.00 fps(r): Video: mpeg2video, yuv420p, 720x480, 7800 kb/s
19:00:08: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
19:00:08: Output #0, rawvideo, to 'C:\Movies\Click\mvn-clickts01_S2DPAL.mpv':
19:00:08: Stream #0.0, 25.00 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 7800 kb/s
19:00:08: Output #1, mp2, to 'C:\Movies\Click\mvn-clickts01_S2DPAL.mp2':
19:00:08: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
19:00:08: Stream mapping:
19:00:08: Stream #0.0 -> #0.0
19:00:08: Stream #0.1 -> #1.0
19:04:06: video:1998480kB audio:77929kB global headers:0kB muxing overhead -3.753068%
19:04:06: PAL->NTSC: Applying Pulldown mvn-clickts01_S2DPAL.mpv
19:04:06: SVCD2DVD: Convert2NTSC: Converting....
19:12:09: PAL->NTSC: Muxing mvn-clickts01_S2D.mpg
File Size: 693 MB
file=C:\Movies\Click\mvn-clickts02.avi
FormatName=avi
Num_Frames=80536
DurationInSecs=3221
Duration=00:53:41.4
VideoCodec=mpeg4
Width=704
Height=416
Standard=PAL
BitRate=1805
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=128
Audio1Channels=2
19:16:24: Looking for AVI PAR...
19:16:24: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
19:16:24: INFO: [???] File C:\Movies\Click\mvn-clickts01_S2DPAL_pd.mpv looks like an MPEG Video
stream.
19:16:24: INFO: [???] File C:\Movies\Click\mvn-clickts01_S2DPAL.mp2 looks like an MPEG Audio
stream.
19:16:24: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
19:16:24: INFO: [???] Found 1 audio streams and 1 video streams
19:16:24: INFO: [???] Selecting dvdauthor DVD output profile
19:16:24: INFO: [???] Multiplexing video program stream!
19:16:24: INFO: [???] Scanning for header info: Video stream e0
(C:\Movies\Click\mvn-clickts01_S2DPAL_pd.mpv)
19:16:24: INFO: [???] VIDEO STREAM: e0
19:16:24: INFO: [???] Frame width : 720
19:16:24: INFO: [???] Frame height : 480
19:16:24: INFO: [???] Aspect ratio : 16:9 display
19:16:24: INFO: [???] Picture rate : 29.970 frames/sec
19:16:24: INFO: [???] Bit rate : 7800000 bits/sec
19:16:24: INFO: [???] Vbv buffer size : 229376 bytes
19:16:24: INFO: [???] CSPF : 0
19:16:24: INFO: [???] Scanning for header info: Audio stream c0
(C:\Movies\Click\mvn-clickts01_S2DPAL.mp2)
19:16:24: INFO: [???] MPEG AUDIO STREAM: c0
19:16:24: INFO: [???] Audio version : 1.0
19:16:24: INFO: [???] Layer : 2
19:16:24: INFO: [???] CRC checksums : no
19:16:24: INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
19:16:24: INFO: [???] Frequency : 48000 Hz
19:16:24: INFO: [???] Mode : 0 stereo
19:16:24: INFO: [???] Mode extension : 0
19:16:24: INFO: [???] Copyright bit : 0 no copyright
19:16:24: INFO: [???] Original/Copy : 1 original
19:16:24: INFO: [???] Emphasis : 0 none
19:16:24: INFO: [???] SYSTEMS/PROGRAM stream:
19:16:24: INFO: [???] rough-guess multiplexed stream data rate : 8195200
19:16:24: INFO: [???] target data-rate specified : 10080000
19:16:24: INFO: [???] Setting specified specified data rate: 10080000
19:16:24: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
19:16:24: INFO: [???] New sequence commences...
19:16:24: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
19:16:24: INFO: [???] Audio c0: buf= 0 frame=000000 sector=00000000
19:16:24: INFO: [???] STREAM e0 completed @ frame 71248.
19:16:24: INFO: [???] STREAM c0 completed @ frame 118748.
19:16:24: INFO: [???] Multiplex completion at SCR=256503222.
19:16:24: INFO: [???] Video e0: buf= 62343 frame=071248 sector=01013006
19:16:24: INFO: [???] Audio c0: buf= 2688 frame=118748 sector=00039505
19:16:24: INFO: [???] VIDEO_STATISTICS: e0
19:16:24: INFO: [???] Video Stream length: 2046443145 bytes
19:16:24: INFO: [???] Sequence headers: 4801
19:16:24: INFO: [???] Sequence ends : 0
19:16:24: INFO: [???] No. Pictures : 71249
19:16:24: INFO: [???] No. Groups : 4801
19:16:24: INFO: [???] No. I Frames : 4801 avg. size 53898 bytes
19:16:24: INFO: [???] No. P Frames : 18950 avg. size 40812 bytes
19:16:24: INFO: [???] No. B Frames : 47499 avg. size 21353 bytes
19:16:24: INFO: [???] Average bit-rate : 5744000 bits/sec
19:16:24: INFO: [???] Peak bit-rate : 9612800 bits/sec
19:16:24: INFO: [???] BUFFERING min 15 Buf max 171704
19:16:24: INFO: [???] AUDIO_STATISTICS: c0
19:16:24: INFO: [???] Audio stream length 79799328 bytes.
19:16:24: INFO: [???] Syncwords : 118749
19:16:24: INFO: [???] Frames : 118749 padded
19:16:24: INFO: [???] Frames : 0 unpadded
19:16:24: INFO: [???] BUFFERING min 15 Buf max 683
19:16:24: INFO: [???] MUX STATUS: no under-runs detected.
Pass 1/1: Processing mvn-clickts02.avi
19:16:26: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
19:16:26: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug
--enable-pthreads
19:16:26: libavutil version: 49.0.0
19:16:26: libavcodec version: 51.4.0
19:16:26: libavformat version: 50.2.1
19:16:26: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
19:16:26: Input #0, avi, from 'C:\Movies\Click\mvn-clickts02.avi':
19:16:26: Duration: 00:53:41.4, start: 0.000000, bitrate: 1805 kb/s
19:16:26: Stream #0.0, 25.00 fps(r): Video: mpeg4, yuv420p, 704x416
19:16:26: Output #0, dvd, to 'C:\Movies\Click\mvn-clickts02_S2D.mpg':
19:16:26: Stream #0.0, 25.00 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 5752
kb/s
19:16:26: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
19:16:26: Stream mapping:
19:16:26: Stream #0.0 -> #0.0
19:16:26: Stream #0.1 -> #0.1
19:43:46: AVI2MPG: done.
PAL->NTSC: demuxing mvn-clickts02_S2D.mpg
THIS IS WITH 2.0 AND IT DID"NT HAVE THE SAME ISSUE AS 2.1
Title: 2.0
Version: 2.0.2117.24512
Executable size: 2.51 MB
Executable size in bytes: 2633811
Executable CreationTime: 10/18/2005 7:21:08 PM
Executable LastWriteTime: 6/29/2006 10:04:25 PM
Executable LastAccessTime: 6/29/2006 10:04:38 PM
Version : 5.1.2600
OSLanguage: 1033
CodeSet: 1252
CountryCode: 1
Local: 0409
Free Physical Memory: 580 MB
DomainRole:
User Name: MAINRIG\
CPU Speed: 2.088GHz
CPU FSB: 166MHz
Video Ram: 128 MB
Status: OK
Mode:
Video Ram: 128 MB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 68.8 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 36.1 GB
<SVCD2DVD DateTime="6/29/2006 6:06:20 PM"><AssetSet><Asset
ID="468da335-25f3-4988-8828-25e2c8369dd5" Path="C:\Movies\Click" Filename="mvn-clickts01.avi"
/><Asset ID="abd850aa-878e-4649-b2bc-b11774ddb234" Path="C:\Movies\Click"
Name="mvn-clickts01.avi" AssetID="468da335-25f3-4988-8828-25e2c8369dd5" MplexOffset="0"
/><Title Name="mvn-clickts02.avi" AssetID="abd850aa-878e-4649-b2bc-b11774ddb234"
MplexOffset="0" /></TitleSet><DVDMenu TVStandard="NTSC" Normal="-1" Highlight="-65536"
Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0"
DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2\default.jpg"
AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="D:\Downloads\SVCD
Movies" InitialDVDFolder="D:\Downloads\SVCD Movies" InitialProjectFolder="D:\Downloads\SVCD
Movies" DeleteS2DFiles="True" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa"
DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma"
FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" EncodeVideo2AudioDuration="False"
/><Process AudioEncoding="mpa" Chapters="Every 30 mins" SkipMPA48="False" SkipAC3="True"
PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False"
AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix=""
NonIntraMatrix="" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True"
/><Burning BurningMethod="DVD Decrypter" DVDDrive="SONY DVD RW DRU-710A "
FormatName=avi
Num_Frames=71250
DurationInSecs=2850
Duration=00:47:30.0
VideoCodec=mpeg4
Width=704
Height=416
Standard=PAL
BitRate=2069
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=128
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
18:06:20: Looking for AVI PAR...
18:06:21: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
18:06:21: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug
--enable-vhook
18:06:21: built on Oct 8 2005 16:10:52, gcc: 3.2.3 (mingw special 20030504-1)
18:06:21: Input #0, avi, from 'C:\Movies\Click\mvn-clickts01.avi':
18:06:21: Duration: 00:47:30.0, start: 0.000000, bitrate: 2069 kb/s
18:06:21: Stream #0.0, 25.00 fps: Video: mpeg4, yuv420p, 704x416
18:06:21: Output #0, dvd, to 'C:\Movies\Click\mvn-clickts01_S2D.mpg':
18:06:21: Stream #0.0, 25.00 fps: Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 5752 kb/s
18:06:21: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
18:06:21: Stream mapping:
18:06:21: Stream #0.0 -> #0.0
18:06:21: Stream #0.1 -> #0.1
18:50:24: video:1998522kB audio:77929kB global headers:0kB muxing overhead 1.890776%
18:50:24: AVI2MPG: done.
18:50:25: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
18:50:25: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug
--enable-vhook
18:50:25: built on Oct 8 2005 16:10:52, gcc: 3.2.3 (mingw special 20030504-1)
18:50:25: Input #0, mpeg, from 'C:\Movies\Click\mvn-clickts01_S2DPAL.mpg':
18:50:25: Duration: 00:47:29.7, start: 0.500000, bitrate: 6081 kb/s
18:50:25: Stream #0.0[0x1e0], 25.00 fps: Video: mpeg2video, yuv420p, 720x480, 7800 kb/s
18:50:25: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
18:50:25: Output #0, rawvideo, to 'C:\Movies\Click\mvn-clickts01_S2DPAL.mpv':
18:50:25: Stream #0.0, 25.00 fps: Video: mpeg2video, 720x480, q=2-31, 7800 kb/s
18:50:25: Output #1, mp2, to 'C:\Movies\Click\mvn-clickts01_S2DPAL.mp2':
18:50:25: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
18:50:25: Stream mapping:
18:50:25: Stream #0.0 -> #0.0
18:50:25: Stream #0.1 -> #1.0
18:54:23: PAL->NTSC: Applying Pulldown mvn-clickts01_S2DPAL.mpv
18:54:23: video:1998522kB audio:77929kB global headers:0kB muxing overhead -3.752992%
18:54:23: SVCD2DVD: Convert2NTSC: Converting....
19:02:17: PAL->NTSC: Muxing mvn-clickts01_S2D.mpg
FormatName=avi
Num_Frames=80536
DurationInSecs=3221
Duration=00:53:41.4
VideoCodec=mpeg4
Width=704
Height=416
Standard=PAL
BitRate=1805
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=128
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
19:06:16: Looking for AVI PAR...
19:06:17: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
19:06:17: INFO: [???] File C:\Movies\Click\mvn-clickts01_S2DPAL_pd.mpv looks like an MPEG Video
stream.
19:06:17: INFO: [???] File C:\Movies\Click\mvn-clickts01_S2DPAL.mp2 looks like an MPEG Audio
stream.
19:06:17: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
19:06:17: INFO: [???] Found 1 audio streams and 1 video streams
19:06:17: INFO: [???] Selecting dvdauthor DVD output profile
19:06:17: INFO: [???] Multiplexing video program stream!
19:06:17: INFO: [???] Scanning for header info: Video stream e0
19:06:17: INFO: [???] VIDEO STREAM: e0
19:06:17: INFO: [???] Frame width : 720
19:06:17: INFO: [???] Frame height : 480
19:06:17: INFO: [???] Aspect ratio : 16:9 display
19:06:17: INFO: [???] Picture rate : 29.970 frames/sec
19:06:17: INFO: [???] Bit rate : 7800000 bits/sec
19:06:17: INFO: [???] Vbv buffer size : 229376 bytes
19:06:17: INFO: [???] CSPF : 0
19:06:17: INFO: [???] Scanning for header info: Audio stream c0
19:06:17: INFO: [???] MPEG AUDIO STREAM: c0
19:06:17: INFO: [???] Audio version : 1.0
19:06:17: INFO: [???] Layer : 2
19:06:17: INFO: [???] CRC checksums : no
19:06:17: INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
19:06:17: INFO: [???] Frequency : 48000 Hz
19:06:17: INFO: [???] Mode : 0 stereo
19:06:17: INFO: [???] Mode extension : 0
19:06:17: INFO: [???] Copyright bit : 0 no copyright
19:06:17: INFO: [???] Original/Copy : 1 original
19:06:17: INFO: [???] Emphasis : 0 none
19:06:17: INFO: [???] SYSTEMS/PROGRAM stream:
19:06:17: INFO: [???] rough-guess multiplexed stream data rate : 8195200
19:06:17: INFO: [???] target data-rate specified : 10080000
19:06:17: INFO: [???] Setting specified specified data rate: 10080000
19:06:17: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
19:06:17: INFO: [???] New sequence commences...
19:06:17: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
19:06:17: INFO: [???] Audio c0: buf= 0 frame=000000 sector=00000000
19:06:17: INFO: [???] STREAM e0 completed @ frame 71248.
19:06:17: INFO: [???] STREAM c0 completed @ frame 118748.
19:06:17: INFO: [???] Multiplex completion at SCR=256503222.
19:06:17: INFO: [???] Video e0: buf= 60469 frame=071248 sector=01013213
19:06:17: INFO: [???] Audio c0: buf= 2688 frame=118748 sector=00039505
19:06:17: INFO: [???] VIDEO_STATISTICS: e0
19:06:17: INFO: [???] Video Stream length: 2046486465 bytes
19:06:17: INFO: [???] Sequence headers: 5089
19:06:17: INFO: [???] Sequence ends : 0
19:06:17: INFO: [???] No. Pictures : 71249
19:06:17: INFO: [???] No. Groups : 5089
19:06:17: INFO: [???] No. I Frames : 5089 avg. size 53986 bytes
19:06:17: INFO: [???] No. P Frames : 18662 avg. size 40696 bytes
19:06:17: INFO: [???] No. B Frames : 47499 avg. size 21310 bytes
19:06:17: INFO: [???] Average bit-rate : 5744000 bits/sec
19:06:17: INFO: [???] Peak bit-rate : 12630000 bits/sec
19:06:17: INFO: [???] BUFFERING min 15 Buf max 172765
19:06:17: INFO: [???] AUDIO_STATISTICS: c0
19:06:17: INFO: [???] Audio stream length 79799328 bytes.
19:06:17: INFO: [???] Syncwords : 118749
19:06:17: INFO: [???] Frames : 118749 padded
19:06:17: INFO: [???] Frames : 0 unpadded
19:06:17: INFO: [???] BUFFERING min 15 Buf max 683
19:06:17: INFO: [???] MUX STATUS: no under-runs detected.
19:06:19: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
19:06:19: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug
--enable-vhook
19:06:19: built on Oct 8 2005 16:10:52, gcc: 3.2.3 (mingw special 20030504-1)
19:06:19: Input #0, avi, from 'C:\Movies\Click\mvn-clickts02.avi':
19:06:19: Duration: 00:53:41.4, start: 0.000000, bitrate: 1805 kb/s
19:06:19: Stream #0.0, 25.00 fps: Video: mpeg4, yuv420p, 704x416
19:06:19: Output #0, dvd, to 'C:\Movies\Click\mvn-clickts02_S2D.mpg':
19:06:19: Stream #0.0, 25.00 fps: Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 5752 kb/s
19:06:19: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
19:06:19: Stream mapping:
19:06:19: Stream #0.0 -> #0.0
19:06:19: Stream #0.1 -> #0.1
19:55:36: video:2259621kB audio:88085kB global headers:0kB muxing overhead 1.891700%
19:55:36: AVI2MPG: done.
19:55:37: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
19:55:37: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug
--enable-vhook
19:55:37: built on Oct 8 2005 16:10:52, gcc: 3.2.3 (mingw special 20030504-1)
19:55:37: Input #0, mpeg, from 'C:\Movies\Click\mvn-clickts02_S2DPAL.mpg':
19:55:37: Duration: 00:53:41.2, start: 0.500000, bitrate: 6083 kb/s
19:55:37: Stream #0.0[0x1e0], 25.00 fps: Video: mpeg2video, yuv420p, 720x480, 7800 kb/s
19:55:37: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
19:55:37: Output #0, rawvideo, to 'C:\Movies\Click\mvn-clickts02_S2DPAL.mpv':
19:55:37: Stream #0.0, 25.00 fps: Video: mpeg2video, 720x480, q=2-31, 7800 kb/s
19:55:37: Output #1, mp2, to 'C:\Movies\Click\mvn-clickts02_S2DPAL.mp2':
19:55:37: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
19:55:37: Stream mapping:
19:55:37: Stream #0.0 -> #0.0
19:55:37: Stream #0.1 -> #1.0
19:59:27: video:2259621kB audio:88085kB global headers:0kB muxing overhead -3.751966%
19:59:27: PAL->NTSC: Applying Pulldown mvn-clickts02_S2DPAL.mpv
19:59:27: SVCD2DVD: Convert2NTSC: Converting....
20:08:20: PAL->NTSC: Muxing mvn-clickts02_S2D.mpg
20:12:30: Done: Processing assets for DVD creation
Authoring DVD Folders
20:12:30: Creating TitleSet # 1
20:12:30: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
20:12:30: -->: DVDFolders creating VTS
20:12:30: -->: VTS 01
20:12:30:
DVD Folders: Processing C:\Movies\Click\mvn-clickts01_S2D.mpg...
20:12:30: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
20:12:30: INFO: [???] File C:\Movies\Click\mvn-clickts02_S2DPAL_pd.mpv looks like an MPEG Video
stream.
20:12:30: INFO: [???] File C:\Movies\Click\mvn-clickts02_S2DPAL.mp2 looks like an MPEG Audio
stream.
20:12:30: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
20:12:30: INFO: [???] Found 1 audio streams and 1 video streams
20:12:30: INFO: [???] Selecting dvdauthor DVD output profile
20:12:30: INFO: [???] Multiplexing video program stream!
20:12:30: INFO: [???] Scanning for header info: Video stream e0
(C:\Movies\Click\mvn-clickts02_S2DPAL_pd.mpv)
20:12:30: INFO: [???] VIDEO STREAM: e0
20:12:30: INFO: [???] Frame width : 720
20:12:30: INFO: [???] Frame height : 480
20:12:30: INFO: [???] Aspect ratio : 16:9 display
20:12:30: INFO: [???] Picture rate : 29.970 frames/sec
20:12:30: INFO: [???] Bit rate : 7800000 bits/sec
20:12:30: INFO: [???] Vbv buffer size : 229376 bytes
20:12:30: INFO: [???] CSPF : 0
20:12:30: INFO: [???] Scanning for header info: Audio stream c0
(C:\Movies\Click\mvn-clickts02_S2DPAL.mp2)
20:12:30: INFO: [???] MPEG AUDIO STREAM: c0
20:12:30: INFO: [???] Audio version : 1.0
20:12:30: INFO: [???] Layer : 2
20:12:30: INFO: [???] CRC checksums : no
20:12:30: INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
20:12:30: INFO: [???] Frequency : 48000 Hz
20:12:30: INFO: [???] Mode : 0 stereo
20:12:30: INFO: [???] Mode extension : 0
20:12:30: INFO: [???] Copyright bit : 0 no copyright
20:12:30: INFO: [???] Original/Copy : 1 original
20:12:30: INFO: [???] Emphasis : 0 none
20:12:30: INFO: [???] SYSTEMS/PROGRAM stream:
20:12:30: INFO: [???] rough-guess multiplexed stream data rate : 8195200
20:12:30: INFO: [???] target data-rate specified : 10080000
20:12:30: INFO: [???] Setting specified specified data rate: 10080000
20:12:30: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
20:12:30: INFO: [???] New sequence commences...
20:12:30: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
20:12:30: INFO: [???] Audio c0: buf= 0 frame=000000 sector=00000000
20:12:30: INFO: [???] STREAM e0 completed @ frame 80534.
20:12:30: INFO: [???] STREAM c0 completed @ frame 134224.
20:12:30: INFO: [???] Multiplex completion at SCR=289933604.
20:12:30: INFO: [???] Video e0: buf= 36967 frame=080534 sector=01145505
20:12:30: INFO: [???] Audio c0: buf= 2016 frame=134224 sector=00044654
20:12:30: INFO: [???] VIDEO_STATISTICS: e0
20:12:30: INFO: [???] Video Stream length: 2313852189 bytes
20:12:30: INFO: [???] Sequence headers: 5666
20:12:30: INFO: [???] Sequence ends : 0
20:12:30: INFO: [???] No. Pictures : 80535
20:12:30: INFO: [???] No. Groups : 5666
20:12:30: INFO: [???] No. I Frames : 5666 avg. size 51739 bytes
20:12:30: INFO: [???] No. P Frames : 21180 avg. size 40863 bytes
20:12:30: INFO: [???] No. B Frames : 53690 avg. size 21515 bytes
20:12:30: INFO: [???] Average bit-rate : 5746000 bits/sec
20:12:30: INFO: [???] Peak bit-rate : 13089600 bits/sec
20:12:30: INFO: [???] BUFFERING min 15 Buf max 144428
20:12:30: INFO: [???] AUDIO_STATISTICS: c0
20:12:30: INFO: [???] Audio stream length 90199200 bytes.
20:12:30: INFO: [???] Syncwords : 134225
20:12:30: INFO: [???] Frames : 134225 padded
20:12:30: INFO: [???] Frames : 0 unpadded
20:12:30: INFO: [???] BUFFERING min 15 Buf max 683
20:12:30: INFO: [???] MUX STATUS: no under-runs detected.
20:17:20:
DVD Folders: Processing C:\Movies\Click\mvn-clickts02_S2D.mpg...
20:22:04:
20:25:00:
20:25:00: Finalising DVD...
20:25:00: SVCD2DVD: DVDfolders
20:25:00: -->: DVDFolders creating table of contents
20:25:00: scanning D:\Downloads\SVCD Movies\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
20:25:00: Finalising DVD...Done
20:25:00: Done: Authoring DVD Folders
Burning DVD folder
20:25:00: Creating ISO...
20:25:05: 0.22% done, estimate finish Thu Jun 29 20:40:01 2006
20:25:08: 0.44% done, estimate finish Thu Jun 29 20:47:33 2006
20:25:11: 0.67% done, estimate finish Thu Jun 29 20:47:33 2006
20:25:14: 0.89% done, estimate finish Thu Jun 29 20:47:34 2006
20:25:14: 1.11% done, estimate finish Thu Jun 29 20:43:03 2006
20:25:16: 1.33% done, estimate finish Thu Jun 29 20:42:33 2006
20:25:17: 1.55% done, estimate finish Thu Jun 29 20:41:07 2006
20:25:18: 1.77% done, estimate finish Thu Jun 29 20:40:03 2006
20:25:19: 2.00% done, estimate finish Thu Jun 29 20:39:13 2006
20:25:21: 2.22% done, estimate finish Thu Jun 29 20:39:18 2006
20:25:23: 2.44% done, estimate finish Thu Jun 29 20:39:22 2006
20:25:24: 2.66% done, estimate finish Thu Jun 29 20:38:48 2006
20:25:26: 2.88% done, estimate finish Thu Jun 29 20:38:54 2006
20:25:27: 3.11% done, estimate finish Thu Jun 29 20:38:26 2006
20:25:28: 3.33% done, estimate finish Thu Jun 29 20:38:03 2006
20:25:29: 3.55% done, estimate finish Thu Jun 29 20:37:42 2006
20:25:30: 3.77% done, estimate finish Thu Jun 29 20:37:24 2006
20:25:32: 3.99% done, estimate finish Thu Jun 29 20:37:33 2006
20:25:33: 4.22% done, estimate finish Thu Jun 29 20:37:17 2006
20:25:34: 4.44% done, estimate finish Thu Jun 29 20:37:03 2006
20:25:36: 4.66% done, estimate finish Thu Jun 29 20:37:11 2006
20:25:36: 4.88% done, estimate finish Thu Jun 29 20:36:38 2006
20:25:37: 5.10% done, estimate finish Thu Jun 29 20:36:27 2006
20:25:38: 5.32% done, estimate finish Thu Jun 29 20:36:18 2006
20:25:40: 5.55% done, estimate finish Thu Jun 29 20:36:27 2006
20:25:41: 5.77% done, estimate finish Thu Jun 29 20:36:18 2006
20:25:42: 5.99% done, estimate finish Thu Jun 29 20:36:09 2006
20:25:43: 6.21% done, estimate finish Thu Jun 29 20:36:02 2006
20:25:44: 6.43% done, estimate finish Thu Jun 29 20:35:54 2006
20:25:45: 6.65% done, estimate finish Thu Jun 29 20:35:48 2006
20:25:47: 6.88% done, estimate finish Thu Jun 29 20:35:56 2006
20:25:47: 7.10% done, estimate finish Thu Jun 29 20:35:35 2006
20:25:49: 7.32% done, estimate finish Thu Jun 29 20:35:44 2006
20:25:50: 7.54% done, estimate finish Thu Jun 29 20:35:38 2006
20:25:51: 7.76% done, estimate finish Thu Jun 29 20:35:33 2006
20:25:53: 7.99% done, estimate finish Thu Jun 29 20:35:40 2006
20:25:54: 8.21% done, estimate finish Thu Jun 29 20:35:35 2006
20:25:56: 8.43% done, estimate finish Thu Jun 29 20:35:42 2006
20:25:57: 8.65% done, estimate finish Thu Jun 29 20:35:37 2006
20:25:57: 8.87% done, estimate finish Thu Jun 29 20:35:21 2006
20:25:59: 9.09% done, estimate finish Thu Jun 29 20:35:28 2006
20:26:00: 9.32% done, estimate finish Thu Jun 29 20:35:24 2006
20:26:02: 9.54% done, estimate finish Thu Jun 29 20:35:31 2006
20:26:03: 9.76% done, estimate finish Thu Jun 29 20:35:26 2006
20:26:05: 9.98% done, estimate finish Thu Jun 29 20:35:33 2006
20:26:07: 10.20% done, estimate finish Thu Jun 29 20:35:39 2006
20:26:07: 10.43% done, estimate finish Thu Jun 29 20:35:25 2006
20:26:08: 10.65% done, estimate finish Thu Jun 29 20:35:21 2006
20:26:10: 10.87% done, estimate finish Thu Jun 29 20:35:27 2006
20:26:11: 11.09% done, estimate finish Thu Jun 29 20:35:24 2006
20:26:13: 11.31% done, estimate finish Thu Jun 29 20:35:29 2006
20:26:14: 11.53% done, estimate finish Thu Jun 29 20:35:26 2006
20:26:16: 11.76% done, estimate finish Thu Jun 29 20:35:31 2006
20:26:16: 11.98% done, estimate finish Thu Jun 29 20:35:19 2006
20:26:18: 12.20% done, estimate finish Thu Jun 29 20:35:24 2006
20:26:19: 12.42% done, estimate finish Thu Jun 29 20:35:21 2006
20:26:21: 12.64% done, estimate finish Thu Jun 29 20:35:26 2006
20:26:22: 12.87% done, estimate finish Thu Jun 29 20:35:23 2006
20:26:22: 13.09% done, estimate finish Thu Jun 29 20:35:13 2006
20:26:23: 13.31% done, estimate finish Thu Jun 29 20:35:10 2006
20:26:25: 13.53% done, estimate finish Thu Jun 29 20:35:15 2006
20:26:26: 13.75% done, estimate finish Thu Jun 29 20:35:12 2006
20:26:27: 13.97% done, estimate finish Thu Jun 29 20:35:10 2006
20:26:28: 14.20% done, estimate finish Thu Jun 29 20:35:07 2006
20:26:29: 14.42% done, estimate finish Thu Jun 29 20:35:05 2006
20:26:31: 14.64% done, estimate finish Thu Jun 29 20:35:09 2006
20:26:32: 14.86% done, estimate finish Thu Jun 29 20:35:07 2006
20:26:33: 15.08% done, estimate finish Thu Jun 29 20:35:05 2006
20:26:34: 15.31% done, estimate finish Thu Jun 29 20:35:03 2006
20:26:36: 15.53% done, estimate finish Thu Jun 29 20:35:07 2006
20:26:37: 15.75% done, estimate finish Thu Jun 29 20:35:05 2006
20:26:38: 15.97% done, estimate finish Thu Jun 29 20:35:03 2006
20:26:39: 16.19% done, estimate finish Thu Jun 29 20:35:01 2006
20:26:40: 16.41% done, estimate finish Thu Jun 29 20:34:59 2006
20:26:42: 16.64% done, estimate finish Thu Jun 29 20:35:03 2006
20:26:43: 16.86% done, estimate finish Thu Jun 29 20:35:01 2006
20:26:44: 17.08% done, estimate finish Thu Jun 29 20:34:59 2006
20:26:46: 17.30% done, estimate finish Thu Jun 29 20:35:03 2006
20:26:46: 17.52% done, estimate finish Thu Jun 29 20:34:55 2006
20:26:47: 17.75% done, estimate finish Thu Jun 29 20:34:53 2006
20:26:48: 17.97% done, estimate finish Thu Jun 29 20:34:51 2006
20:26:49: 18.19% done, estimate finish Thu Jun 29 20:34:50 2006
20:26:50: 18.41% done, estimate finish Thu Jun 29 20:34:48 2006
20:26:51: 18.63% done, estimate finish Thu Jun 29 20:34:46 2006
20:26:52: 18.85% done, estimate finish Thu Jun 29 20:34:45 2006
20:26:54: 19.08% done, estimate finish Thu Jun 29 20:34:49 2006
20:26:55: 19.30% done, estimate finish Thu Jun 29 20:34:47 2006
20:26:57: 19.52% done, estimate finish Thu Jun 29 20:34:51 2006
20:26:58: 19.74% done, estimate finish Thu Jun 29 20:34:49 2006
20:26:59: 19.96% done, estimate finish Thu Jun 29 20:34:48 2006
20:27:00: 20.19% done, estimate finish Thu Jun 29 20:34:46 2006
20:27:01: 20.41% done, estimate finish Thu Jun 29 20:34:45 2006
20:27:02: 20.63% done, estimate finish Thu Jun 29 20:34:43 2006
20:27:03: 20.85% done, estimate finish Thu Jun 29 20:34:42 2006
20:27:04: 21.07% done, estimate finish Thu Jun 29 20:34:40 2006
20:27:05: 21.29% done, estimate finish Thu Jun 29 20:34:39 2006
20:27:07: 21.52% done, estimate finish Thu Jun 29 20:34:42 2006
20:27:07: 21.74% done, estimate finish Thu Jun 29 20:34:37 2006
20:27:09: 21.96% done, estimate finish Thu Jun 29 20:34:40 2006
20:27:10: 22.18% done, estimate finish Thu Jun 29 20:34:39 2006
20:27:11: 22.40% done, estimate finish Thu Jun 29 20:34:37 2006
20:27:13: 22.63% done, estimate finish Thu Jun 29 20:34:41 2006
20:27:14: 22.85% done, estimate finish Thu Jun 29 20:34:39 2006
20:27:15: 23.07% done, estimate finish Thu Jun 29 20:34:38 2006
20:27:16: 23.29% done, estimate finish Thu Jun 29 20:34:37 2006
20:27:17: 23.51% done, estimate finish Thu Jun 29 20:34:36 2006
20:27:18: 23.73% done, estimate finish Thu Jun 29 20:34:35 2006
20:27:19: 23.96% done, estimate finish Thu Jun 29 20:34:33 2006
20:27:20: 24.18% done, estimate finish Thu Jun 29 20:34:32 2006
20:27:21: 24.40% done, estimate finish Thu Jun 29 20:34:31 2006
20:27:22: 24.62% done, estimate finish Thu Jun 29 20:34:30 2006
20:27:24: 24.84% done, estimate finish Thu Jun 29 20:34:33 2006
20:27:25: 25.07% done, estimate finish Thu Jun 29 20:34:32 2006
20:27:27: 25.29% done, estimate finish Thu Jun 29 20:34:35 2006
20:27:28: 25.51% done, estimate finish Thu Jun 29 20:34:34 2006
20:27:29: 25.73% done, estimate finish Thu Jun 29 20:34:33 2006
20:27:30: 25.95% done, estimate finish Thu Jun 29 20:34:32 2006
20:27:30: 26.17% done, estimate finish Thu Jun 29 20:34:27 2006
20:27:32: 26.40% done, estimate finish Thu Jun 29 20:34:30 2006
20:27:33: 26.62% done, estimate finish Thu Jun 29 20:34:29 2006
20:27:34: 26.84% done, estimate finish Thu Jun 29 20:34:28 2006
20:27:35: 27.06% done, estimate finish Thu Jun 29 20:34:27 2006
20:27:37: 27.28% done, estimate finish Thu Jun 29 20:34:30 2006
20:27:38: 27.51% done, estimate finish Thu Jun 29 20:34:29 2006
20:27:39: 27.73% done, estimate finish Thu Jun 29 20:34:28 2006
20:27:40: 27.95% done, estimate finish Thu Jun 29 20:34:27 2006
20:27:41: 28.17% done, estimate finish Thu Jun 29 20:34:26 2006
20:27:43: 28.39% done, estimate finish Thu Jun 29 20:34:29 2006
20:27:44: 28.61% done, estimate finish Thu Jun 29 20:34:28 2006
20:27:46: 28.84% done, estimate finish Thu Jun 29 20:34:30 2006
20:27:47: 29.06% done, estimate finish Thu Jun 29 20:34:26 2006
20:27:48: 29.28% done, estimate finish Thu Jun 29 20:34:28 2006
20:27:48: 29.50% done, estimate finish Thu Jun 29 20:34:24 2006
20:27:49: 29.72% done, estimate finish Thu Jun 29 20:34:23 2006
20:27:50: 29.95% done, estimate finish Thu Jun 29 20:34:23 2006
20:27:51: 30.17% done, estimate finish Thu Jun 29 20:34:22 2006
20:27:52: 30.39% done, estimate finish Thu Jun 29 20:34:21 2006
20:27:54: 30.61% done, estimate finish Thu Jun 29 20:34:23 2006
20:27:55: 30.83% done, estimate finish Thu Jun 29 20:34:23 2006
20:27:56: 31.05% done, estimate finish Thu Jun 29 20:34:22 2006
20:27:56: 31.28% done, estimate finish Thu Jun 29 20:34:18 2006
20:27:57: 31.50% done, estimate finish Thu Jun 29 20:34:17 2006
20:27:58: 31.72% done, estimate finish Thu Jun 29 20:34:16 2006
20:28:00: 31.94% done, estimate finish Thu Jun 29 20:34:19 2006
20:28:01: 32.16% done, estimate finish Thu Jun 29 20:34:18 2006
20:28:02: 32.38% done, estimate finish Thu Jun 29 20:34:17 2006
20:28:03: 32.61% done, estimate finish Thu Jun 29 20:34:17 2006
20:28:04: 32.83% done, estimate finish Thu Jun 29 20:34:16 2006
20:28:05: 33.05% done, estimate finish Thu Jun 29 20:34:15 2006
20:28:06: 33.27% done, estimate finish Thu Jun 29 20:34:15 2006
20:28:07: 33.49% done, estimate finish Thu Jun 29 20:34:14 2006
20:28:08: 33.72% done, estimate finish Thu Jun 29 20:34:13 2006
20:28:09: 33.94% done, estimate finish Thu Jun 29 20:34:13 2006
20:28:10: 34.16% done, estimate finish Thu Jun 29 20:34:12 2006
20:28:11: 34.38% done, estimate finish Thu Jun 29 20:34:11 2006
20:28:13: 34.60% done, estimate finish Thu Jun 29 20:34:13 2006
20:28:14: 34.83% done, estimate finish Thu Jun 29 20:34:13 2006
20:28:15: 35.05% done, estimate finish Thu Jun 29 20:34:12 2006
20:28:16: 35.27% done, estimate finish Thu Jun 29 20:34:12 2006
20:28:16: 35.49% done, estimate finish Thu Jun 29 20:34:08 2006
20:28:17: 35.71% done, estimate finish Thu Jun 29 20:34:08 2006
20:28:18: 35.93% done, estimate finish Thu Jun 29 20:34:07 2006
20:28:19: 36.16% done, estimate finish Thu Jun 29 20:34:06 2006
20:28:20: 36.38% done, estimate finish Thu Jun 29 20:34:06 2006
20:28:21: 36.60% done, estimate finish Thu Jun 29 20:34:05 2006
20:28:22: 36.82% done, estimate finish Thu Jun 29 20:34:05 2006
20:28:23: 37.04% done, estimate finish Thu Jun 29 20:34:04 2006
20:28:24: 37.26% done, estimate finish Thu Jun 29 20:34:04 2006
20:28:25: 37.49% done, estimate finish Thu Jun 29 20:34:03 2006
20:28:26: 37.71% done, estimate finish Thu Jun 29 20:34:02 2006
20:28:27: 37.93% done, estimate finish Thu Jun 29 20:34:02 2006
20:28:28: 38.15% done, estimate finish Thu Jun 29 20:34:01 2006
20:28:29: 38.37% done, estimate finish Thu Jun 29 20:34:01 2006
20:28:30: 38.60% done, estimate finish Thu Jun 29 20:34:00 2006
20:28:31: 38.82% done, estimate finish Thu Jun 29 20:34:00 2006
20:28:32: 39.04% done, estimate finish Thu Jun 29 20:33:59 2006
20:28:33: 39.26% done, estimate finish Thu Jun 29 20:33:59 2006
20:28:33: 39.48% done, estimate finish Thu Jun 29 20:33:56 2006
20:28:34: 39.71% done, estimate finish Thu Jun 29 20:33:55 2006
20:28:36: 39.93% done, estimate finish Thu Jun 29 20:33:57 2006
20:28:37: 40.15% done, estimate finish Thu Jun 29 20:33:57 2006
20:28:37: 40.37% done, estimate finish Thu Jun 29 20:33:54 2006
20:28:38: 40.59% done, estimate finish Thu Jun 29 20:33:54 2006
20:28:39: 40.81% done, estimate finish Thu Jun 29 20:33:53 2006
20:28:40: 41.04% done, estimate finish Thu Jun 29 20:33:53 2006
20:28:41: 41.26% done, estimate finish Thu Jun 29 20:33:52 2006
20:28:42: 41.48% done, estimate finish Thu Jun 29 20:33:52 2006
20:28:43: 41.70% done, estimate finish Thu Jun 29 20:33:51 2006
20:28:44: 41.92% done, estimate finish Thu Jun 29 20:33:51 2006
20:28:45: 42.14% done, estimate finish Thu Jun 29 20:33:51 2006
20:28:46: 42.37% done, estimate finish Thu Jun 29 20:33:50 2006
20:28:47: 42.59% done, estimate finish Thu Jun 29 20:33:50 2006
20:28:47: 42.81% done, estimate finish Thu Jun 29 20:33:47 2006
20:28:48: 43.03% done, estimate finish Thu Jun 29 20:33:47 2006
20:28:49: 43.25% done, estimate finish Thu Jun 29 20:33:46 2006
20:28:50: 43.48% done, estimate finish Thu Jun 29 20:33:46 2006
20:28:51: 43.70% done, estimate finish Thu Jun 29 20:33:46 2006
20:28:52: 43.92% done, estimate finish Thu Jun 29 20:33:45 2006
20:28:53: 44.14% done, estimate finish Thu Jun 29 20:33:45 2006
20:28:53: 44.36% done, estimate finish Thu Jun 29 20:33:42 2006
20:28:54: 44.59% done, estimate finish Thu Jun 29 20:33:42 2006
20:28:55: 44.81% done, estimate finish Thu Jun 29 20:33:42 2006
20:28:56: 45.03% done, estimate finish Thu Jun 29 20:33:41 2006
20:28:57: 45.25% done, estimate finish Thu Jun 29 20:33:41 2006
20:28:57: 45.47% done, estimate finish Thu Jun 29 20:33:38 2006
20:28:58: 45.69% done, estimate finish Thu Jun 29 20:33:38 2006
20:28:59: 45.92% done, estimate finish Thu Jun 29 20:33:38 2006
20:29:00: 46.14% done, estimate finish Thu Jun 29 20:33:37 2006
20:29:01: 46.36% done, estimate finish Thu Jun 29 20:33:37 2006
20:29:02: 46.58% done, estimate finish Thu Jun 29 20:33:37 2006
20:29:03: 46.80% done, estimate finish Thu Jun 29 20:33:36 2006
20:29:04: 47.02% done, estimate finish Thu Jun 29 20:33:36 2006
20:29:04: 47.25% done, estimate finish Thu Jun 29 20:33:34 2006
20:29:05: 47.47% done, estimate finish Thu Jun 29 20:33:33 2006
20:29:06: 47.69% done, estimate finish Thu Jun 29 20:33:33 2006
20:29:06: 47.91% done, estimate finish Thu Jun 29 20:33:31 2006
20:29:07: 48.13% done, estimate finish Thu Jun 29 20:33:30 2006
20:29:09: 48.36% done, estimate finish Thu Jun 29 20:33:32 2006
20:29:09: 48.58% done, estimate finish Thu Jun 29 20:33:30 2006
20:29:10: 48.80% done, estimate finish Thu Jun 29 20:33:30 2006
20:29:11: 49.02% done, estimate finish Thu Jun 29 20:33:29 2006
20:29:12: 49.24% done, estimate finish Thu Jun 29 20:33:29 2006
20:29:13: 49.46% done, estimate finish Thu Jun 29 20:33:29 2006
20:29:13: 49.69% done, estimate finish Thu Jun 29 20:33:27 2006
20:29:14: 49.91% done, estimate finish Thu Jun 29 20:33:26 2006
20:29:16: 50.13% done, estimate finish Thu Jun 29 20:33:28 2006
20:29:16: 50.35% done, estimate finish Thu Jun 29 20:33:26 2006
20:29:17: 50.57% done, estimate finish Thu Jun 29 20:33:26 2006
20:29:18: 50.80% done, estimate finish Thu Jun 29 20:33:25 2006
20:29:19: 51.02% done, estimate finish Thu Jun 29 20:33:25 2006
20:29:20: 51.24% done, estimate finish Thu Jun 29 20:33:25 2006
20:29:20: 51.46% done, estimate finish Thu Jun 29 20:33:23 2006
20:29:21: 51.68% done, estimate finish Thu Jun 29 20:33:23 2006
20:29:22: 51.90% done, estimate finish Thu Jun 29 20:33:22 2006
20:29:23: 52.13% done, estimate finish Thu Jun 29 20:33:22 2006
20:29:24: 52.35% done, estimate finish Thu Jun 29 20:33:22 2006
20:29:25: 52.57% done, estimate finish Thu Jun 29 20:33:22 2006
20:29:26: 52.79% done, estimate finish Thu Jun 29 20:33:22 2006
20:29:26: 53.01% done, estimate finish Thu Jun 29 20:33:19 2006
20:29:27: 53.24% done, estimate finish Thu Jun 29 20:33:19 2006
20:29:28: 53.46% done, estimate finish Thu Jun 29 20:33:19 2006
20:29:29: 53.68% done, estimate finish Thu Jun 29 20:33:19 2006
20:29:30: 53.90% done, estimate finish Thu Jun 29 20:33:19 2006
20:29:31: 54.12% done, estimate finish Thu Jun 29 20:33:19 2006
20:29:32: 54.34% done, estimate finish Thu Jun 29 20:33:18 2006
20:29:33: 54.57% done, estimate finish Thu Jun 29 20:33:18 2006
20:29:33: 54.79% done, estimate finish Thu Jun 29 20:33:16 2006
20:29:34: 55.01% done, estimate finish Thu Jun 29 20:33:16 2006
20:29:35: 55.23% done, estimate finish Thu Jun 29 20:33:16 2006
20:29:36: 55.45% done, estimate finish Thu Jun 29 20:33:16 2006
20:29:37: 55.68% done, estimate finish Thu Jun 29 20:33:15 2006
20:29:37: 55.90% done, estimate finish Thu Jun 29 20:33:13 2006
20:29:38: 56.12% done, estimate finish Thu Jun 29 20:33:13 2006
20:29:39: 56.34% done, estimate finish Thu Jun 29 20:33:13 2006
20:29:40: 56.56% done, estimate finish Thu Jun 29 20:33:13 2006
20:29:40: 56.78% done, estimate finish Thu Jun 29 20:33:11 2006
20:29:41: 57.01% done, estimate finish Thu Jun 29 20:33:11 2006
20:29:42: 57.23% done, estimate finish Thu Jun 29 20:33:11 2006
20:29:43: 57.45% done, estimate finish Thu Jun 29 20:33:11 2006
20:29:44: 57.67% done, estimate finish Thu Jun 29 20:33:10 2006
20:29:45: 57.89% done, estimate finish Thu Jun 29 20:33:10 2006
20:29:47: 58.12% done, estimate finish Thu Jun 29 20:33:12 2006
20:29:47: 58.34% done, estimate finish Thu Jun 29 20:33:10 2006
20:29:48: 58.56% done, estimate finish Thu Jun 29 20:33:10 2006
20:29:49: 58.78% done, estimate finish Thu Jun 29 20:33:10 2006
20:29:50: 59.00% done, estimate finish Thu Jun 29 20:33:10 2006
20:29:51: 59.22% done, estimate finish Thu Jun 29 20:33:09 2006
20:29:52: 59.45% done, estimate finish Thu Jun 29 20:33:09 2006
20:29:52: 59.67% done, estimate finish Thu Jun 29 20:33:08 2006
20:29:53: 59.89% done, estimate finish Thu Jun 29 20:33:07 2006
20:29:54: 60.11% done, estimate finish Thu Jun 29 20:33:07 2006
20:29:55: 60.33% done, estimate finish Thu Jun 29 20:33:07 2006
20:29:56: 60.56% done, estimate finish Thu Jun 29 20:33:07 2006
20:29:56: 60.78% done, estimate finish Thu Jun 29 20:33:05 2006
20:29:57: 61.00% done, estimate finish Thu Jun 29 20:33:05 2006
20:29:58: 61.22% done, estimate finish Thu Jun 29 20:33:05 2006
20:29:59: 61.44% done, estimate finish Thu Jun 29 20:33:05 2006
20:30:00: 61.66% done, estimate finish Thu Jun 29 20:33:05 2006
20:30:00: 61.89% done, estimate finish Thu Jun 29 20:33:03 2006
20:30:01: 62.11% done, estimate finish Thu Jun 29 20:33:03 2006
20:30:02: 62.33% done, estimate finish Thu Jun 29 20:33:03 2006
20:30:03: 62.55% done, estimate finish Thu Jun 29 20:33:03 2006
20:30:04: 62.77% done, estimate finish Thu Jun 29 20:33:03 2006
20:30:07: 63.00% done, estimate finish Thu Jun 29 20:33:06 2006
20:30:07: 63.22% done, estimate finish Thu Jun 29 20:33:04 2006
20:30:08: 63.44% done, estimate finish Thu Jun 29 20:33:04 2006
20:30:08: 63.66% done, estimate finish Thu Jun 29 20:33:02 2006
20:30:09: 63.88% done, estimate finish Thu Jun 29 20:33:02 2006
20:30:10: 64.10% done, estimate finish Thu Jun 29 20:33:02 2006
20:30:11: 64.33% done, estimate finish Thu Jun 29 20:33:02 2006
20:30:12: 64.55% done, estimate finish Thu Jun 29 20:33:02 2006
20:30:13: 64.77% done, estimate finish Thu Jun 29 20:33:02 2006
20:30:14: 64.99% done, estimate finish Thu Jun 29 20:33:02 2006
20:30:15: 65.21% done, estimate finish Thu Jun 29 20:33:01 2006
20:30:16: 65.44% done, estimate finish Thu Jun 29 20:33:01 2006
20:30:16: 65.66% done, estimate finish Thu Jun 29 20:33:00 2006
20:30:17: 65.88% done, estimate finish Thu Jun 29 20:33:00 2006
20:30:18: 66.10% done, estimate finish Thu Jun 29 20:33:00 2006
20:30:19: 66.32% done, estimate finish Thu Jun 29 20:32:59 2006
20:30:20: 66.54% done, estimate finish Thu Jun 29 20:32:59 2006
20:30:21: 66.77% done, estimate finish Thu Jun 29 20:32:59 2006
20:30:22: 66.99% done, estimate finish Thu Jun 29 20:32:59 2006
20:30:23: 67.21% done, estimate finish Thu Jun 29 20:32:59 2006
20:30:24: 67.43% done, estimate finish Thu Jun 29 20:32:59 2006
20:30:25: 67.65% done, estimate finish Thu Jun 29 20:32:59 2006
20:30:26: 67.88% done, estimate finish Thu Jun 29 20:32:59 2006
20:30:27: 68.10% done, estimate finish Thu Jun 29 20:32:59 2006
20:30:27: 68.32% done, estimate finish Thu Jun 29 20:32:57 2006
20:30:28: 68.54% done, estimate finish Thu Jun 29 20:32:57 2006
20:30:29: 68.76% done, estimate finish Thu Jun 29 20:32:57 2006
20:30:30: 68.98% done, estimate finish Thu Jun 29 20:32:57 2006
20:30:31: 69.21% done, estimate finish Thu Jun 29 20:32:57 2006
20:30:32: 69.43% done, estimate finish Thu Jun 29 20:32:57 2006
20:30:33: 69.65% done, estimate finish Thu Jun 29 20:32:57 2006
20:30:34: 69.87% done, estimate finish Thu Jun 29 20:32:57 2006
20:30:36: 70.09% done, estimate finish Thu Jun 29 20:32:58 2006
20:30:37: 70.32% done, estimate finish Thu Jun 29 20:32:58 2006
20:30:37: 70.54% done, estimate finish Thu Jun 29 20:32:56 2006
20:30:38: 70.76% done, estimate finish Thu Jun 29 20:32:56 2006
20:30:39: 70.98% done, estimate finish Thu Jun 29 20:32:56 2006
20:30:40: 71.20% done, estimate finish Thu Jun 29 20:32:56 2006
20:30:41: 71.42% done, estimate finish Thu Jun 29 20:32:56 2006
20:30:41: 71.65% done, estimate finish Thu Jun 29 20:32:55 2006
20:30:42: 71.87% done, estimate finish Thu Jun 29 20:32:55 2006
20:30:43: 72.09% done, estimate finish Thu Jun 29 20:32:55 2006
20:30:44: 72.31% done, estimate finish Thu Jun 29 20:32:54 2006
20:30:45: 72.53% done, estimate finish Thu Jun 29 20:32:54 2006
20:30:47: 72.75% done, estimate finish Thu Jun 29 20:32:56 2006
20:30:47: 72.98% done, estimate finish Thu Jun 29 20:32:54 2006
20:30:48: 73.20% done, estimate finish Thu Jun 29 20:32:54 2006
20:30:49: 73.42% done, estimate finish Thu Jun 29 20:32:54 2006
20:30:50: 73.64% done, estimate finish Thu Jun 29 20:32:54 2006
20:30:51: 73.86% done, estimate finish Thu Jun 29 20:32:54 2006
20:30:52: 74.09% done, estimate finish Thu Jun 29 20:32:54 2006
20:30:52: 74.31% done, estimate finish Thu Jun 29 20:32:53 2006
20:30:53: 74.53% done, estimate finish Thu Jun 29 20:32:52 2006
20:30:54: 74.75% done, estimate finish Thu Jun 29 20:32:52 2006
20:30:55: 74.97% done, estimate finish Thu Jun 29 20:32:52 2006
20:30:56: 75.20% done, estimate finish Thu Jun 29 20:32:52 2006
20:30:57: 75.42% done, estimate finish Thu Jun 29 20:32:52 2006
20:30:58: 75.64% done, estimate finish Thu Jun 29 20:32:52 2006
20:30:59: 75.86% done, estimate finish Thu Jun 29 20:32:52 2006
20:30:59: 76.08% done, estimate finish Thu Jun 29 20:32:51 2006
20:31:00: 76.30% done, estimate finish Thu Jun 29 20:32:51 2006
20:31:01: 76.53% done, estimate finish Thu Jun 29 20:32:51 2006
20:31:02: 76.75% done, estimate finish Thu Jun 29 20:32:51 2006
20:31:02: 76.97% done, estimate finish Thu Jun 29 20:32:49 2006
20:31:03: 77.19% done, estimate finish Thu Jun 29 20:32:49 2006
20:31:04: 77.41% done, estimate finish Thu Jun 29 20:32:49 2006
20:31:06: 77.63% done, estimate finish Thu Jun 29 20:32:50 2006
20:31:07: 77.86% done, estimate finish Thu Jun 29 20:32:50 2006
20:31:08: 78.08% done, estimate finish Thu Jun 29 20:32:50 2006
20:31:08: 78.30% done, estimate finish Thu Jun 29 20:32:49 2006
20:31:09: 78.52% done, estimate finish Thu Jun 29 20:32:49 2006
20:31:09: 78.74% done, estimate finish Thu Jun 29 20:32:48 2006
20:31:10: 78.97% done, estimate finish Thu Jun 29 20:32:48 2006
20:31:11: 79.19% done, estimate finish Thu Jun 29 20:32:47 2006
20:31:12: 79.41% done, estimate finish Thu Jun 29 20:32:47 2006
20:31:13: 79.63% done, estimate finish Thu Jun 29 20:32:47 2006
20:31:14: 79.85% done, estimate finish Thu Jun 29 20:32:47 2006
20:31:15: 80.08% done, estimate finish Thu Jun 29 20:32:47 2006
20:31:16: 80.30% done, estimate finish Thu Jun 29 20:32:47 2006
20:31:17: 80.52% done, estimate finish Thu Jun 29 20:32:47 2006
20:31:18: 80.74% done, estimate finish Thu Jun 29 20:32:47 2006
20:31:18: 80.96% done, estimate finish Thu Jun 29 20:32:46 2006
20:31:19: 81.18% done, estimate finish Thu Jun 29 20:32:46 2006
20:31:20: 81.41% done, estimate finish Thu Jun 29 20:32:46 2006
20:31:21: 81.63% done, estimate finish Thu Jun 29 20:32:46 2006
20:31:22: 81.85% done, estimate finish Thu Jun 29 20:32:46 2006
20:31:23: 82.07% done, estimate finish Thu Jun 29 20:32:46 2006
20:31:23: 82.29% done, estimate finish Thu Jun 29 20:32:44 2006
20:31:24: 82.51% done, estimate finish Thu Jun 29 20:32:44 2006
20:31:25: 82.74% done, estimate finish Thu Jun 29 20:32:44 2006
20:31:26: 82.96% done, estimate finish Thu Jun 29 20:32:44 2006
20:31:27: 83.18% done, estimate finish Thu Jun 29 20:32:44 2006
20:31:27: 83.40% done, estimate finish Thu Jun 29 20:32:43 2006
20:31:28: 83.62% done, estimate finish Thu Jun 29 20:32:43 2006
20:31:29: 83.85% done, estimate finish Thu Jun 29 20:32:43 2006
20:31:30: 84.07% done, estimate finish Thu Jun 29 20:32:43 2006
20:31:31: 84.29% done, estimate finish Thu Jun 29 20:32:43 2006
20:31:31: 84.51% done, estimate finish Thu Jun 29 20:32:42 2006
20:31:33: 84.73% done, estimate finish Thu Jun 29 20:32:43 2006
20:31:33: 84.96% done, estimate finish Thu Jun 29 20:32:42 2006
20:31:34: 85.18% done, estimate finish Thu Jun 29 20:32:42 2006
20:31:36: 85.40% done, estimate finish Thu Jun 29 20:32:42 2006
20:31:37: 85.62% done, estimate finish Thu Jun 29 20:32:43 2006
20:31:37: 85.84% done, estimate finish Thu Jun 29 20:32:42 2006
20:31:38: 86.06% done, estimate finish Thu Jun 29 20:32:42 2006
20:31:39: 86.29% done, estimate finish Thu Jun 29 20:32:42 2006
20:31:40: 86.51% done, estimate finish Thu Jun 29 20:32:42 2006
20:31:41: 86.73% done, estimate finish Thu Jun 29 20:32:42 2006
20:31:41: 86.95% done, estimate finish Thu Jun 29 20:32:40 2006
20:31:42: 87.17% done, estimate finish Thu Jun 29 20:32:40 2006
20:31:43: 87.39% done, estimate finish Thu Jun 29 20:32:40 2006
20:31:44: 87.62% done, estimate finish Thu Jun 29 20:32:40 2006
20:31:45: 87.84% done, estimate finish Thu Jun 29 20:32:40 2006
20:31:46: 88.06% done, estimate finish Thu Jun 29 20:32:40 2006
20:31:47: 88.28% done, estimate finish Thu Jun 29 20:32:40 2006
20:31:47: 88.50% done, estimate finish Thu Jun 29 20:32:39 2006
20:31:48: 88.73% done, estimate finish Thu Jun 29 20:32:39 2006
20:31:49: 88.95% done, estimate finish Thu Jun 29 20:32:39 2006
20:31:50: 89.17% done, estimate finish Thu Jun 29 20:32:39 2006
20:31:51: 89.39% done, estimate finish Thu Jun 29 20:32:39 2006
20:31:51: 89.61% done, estimate finish Thu Jun 29 20:32:38 2006
20:31:52: 89.83% done, estimate finish Thu Jun 29 20:32:38 2006
20:31:53: 90.06% done, estimate finish Thu Jun 29 20:32:38 2006
20:31:53: 90.28% done, estimate finish Thu Jun 29 20:32:37 2006
20:31:54: 90.50% done, estimate finish Thu Jun 29 20:32:37 2006
20:31:56: 90.72% done, estimate finish Thu Jun 29 20:32:38 2006
20:31:57: 90.94% done, estimate finish Thu Jun 29 20:32:38 2006
20:31:57: 91.17% done, estimate finish Thu Jun 29 20:32:37 2006
20:31:58: 91.39% done, estimate finish Thu Jun 29 20:32:37 2006
20:31:59: 91.61% done, estimate finish Thu Jun 29 20:32:37 2006
20:32:00: 91.83% done, estimate finish Thu Jun 29 20:32:37 2006
20:32:01: 92.05% done, estimate finish Thu Jun 29 20:32:37 2006
20:32:01: 92.27% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:02: 92.50% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:03: 92.72% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:04: 92.94% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:05: 93.16% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:06: 93.38% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:07: 93.61% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:08: 93.83% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:09: 94.05% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:10: 94.27% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:11: 94.49% done, estimate finish Thu Jun 29 20:32:36 2006
20:32:11: 94.71% done, estimate finish Thu Jun 29 20:32:34 2006
20:32:12: 94.94% done, estimate finish Thu Jun 29 20:32:34 2006
20:32:13: 95.16% done, estimate finish Thu Jun 29 20:32:34 2006
20:32:14: 95.38% done, estimate finish Thu Jun 29 20:32:34 2006
20:32:15: 95.60% done, estimate finish Thu Jun 29 20:32:34 2006
20:32:15: 95.82% done, estimate finish Thu Jun 29 20:32:33 2006
20:32:16: 96.05% done, estimate finish Thu Jun 29 20:32:33 2006
20:32:17: 96.27% done, estimate finish Thu Jun 29 20:32:33 2006
20:32:18: 96.49% done, estimate finish Thu Jun 29 20:32:33 2006
20:32:18: 96.71% done, estimate finish Thu Jun 29 20:32:32 2006
20:32:19: 96.93% done, estimate finish Thu Jun 29 20:32:32 2006
20:32:20: 97.15% done, estimate finish Thu Jun 29 20:32:32 2006
20:32:21: 97.38% done, estimate finish Thu Jun 29 20:32:32 2006
20:32:22: 97.60% done, estimate finish Thu Jun 29 20:32:32 2006
20:32:23: 97.82% done, estimate finish Thu Jun 29 20:32:32 2006
20:32:23: 98.04% done, estimate finish Thu Jun 29 20:32:31 2006
20:32:24: 98.26% done, estimate finish Thu Jun 29 20:32:31 2006
20:32:25: 98.49% done, estimate finish Thu Jun 29 20:32:31 2006
20:32:26: 98.71% done, estimate finish Thu Jun 29 20:32:31 2006
20:32:27: 98.93% done, estimate finish Thu Jun 29 20:32:31 2006
20:32:28: 99.15% done, estimate finish Thu Jun 29 20:32:31 2006
20:32:28: 99.37% done, estimate finish Thu Jun 29 20:32:30 2006
20:32:29: 99.59% done, estimate finish Thu Jun 29 20:32:30 2006
20:32:30: 99.82% done, estimate finish Thu Jun 29 20:32:30 2006
20:32:31: Total translation table size: 0
20:32:31: Total rockridge attributes bytes: 0
20:32:31: Total di
Thread: Same issue as others with ffmpeg
Can you try taking off "use mutli threads" in the video encoding options. That may help. FYI: I had no problem with your source files...
i was just trying what chrissyboy suggested and my PC crashed while i tried?? i have been having the same problems as above
lee
well it didnt work for me? this time it didnt crash though just got to 91.1% and hung for ages so i had to turn svc2dvd off
lee
i have since found out that it was the source file that was the problem all is ok now
reorder streams with ffmpeg issue
By MarquisdeOz in forum AudioReplies: 6Last Post: 9th Jul 2011, 13:19 -
FFMPeg Issue : Codec ID#
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2010, 15:10 -
ffmpeg cut mpeg2 video issue
By santhoshv in forum EditingReplies: 2Last Post: 28th Oct 2009, 01:11 -
By santhoshv in forum Newbie / General discussionsReplies: 2Last Post: 27th Oct 2009, 03:50 -
gotsent issue (cant find ffmpeg)
By X400 in forum Video ConversionReplies: 1Last Post: 6th Nov 2007, 02:59
Statistics
Newest guides
Latest tool updates
New media comments
