hi all
I downloaded the K-Lite Codec Pack which includes Media Player Classic. Problem is, all the files it plays are upside down! In the FAQ, it says to set the Options > Playback > Output, to "Overlay Mixer" to fix it but it already IS set to that. anyone got any ideas what else I can try?
cheers
daz
There's your problem.Originally Posted by djdust
that was helpful. anyone else?
codec packs are not the way to go. only install known good codecs individually and only if you really need it. too many bad ones out there. which jagabo alluded to. uninstall them all.
Upside down video is a classic sign of the codec not working harmoniously with the media player. When the codec creates the video frame, if it is in RGB format (rather than YUV), it must be properly tagged as an "upside-down device independent bitmap". It's a pain in the ar$e to deal with but not difficult. Sounds like slopping programming to me.
To quote Microsoft's article:
• The scanlines are stored upside down, with the first scan (scan 0) in memory being the bottommost scan in the image.John Miller
enosoft - high performance tools for music and video
Home of the Enosoft DV Processor - Free for personal use!
http://forum.videohelp.com/viewtopic.php?t=150504
Some codecs have a setting that lets you compensate for the problem, Xvid for example.
Playing flac. files using ffdshow and Media Player Classic
By Cunhambebe in forum Newbie / General discussionsReplies: 13Last Post: 5th Jul 2011, 04:32 -
Playing subtitles off VOB file in Media Player Classic
By aduh11 in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2009, 14:44 -
No Sound When playing MKV files in wmp or media player classic
By tmiller_15 in forum Blu-ray RippingReplies: 2Last Post: 12th Jun 2009, 23:24 -
Media Player Classic no longer playing audio for some reason...
By darkzero297 in forum Software PlayingReplies: 5Last Post: 21st Feb 2009, 14:56 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49
