Just a quick question guys, how do we find out the format of a video ?
Say I got MOVIE.MPG how do i know if its mpeg-1 or mpeg-2 or maybe someone renamed it from movie.wmv to movie.mpg . how wud i know its WMV
pls help
it came in my mind when i was burning a mpg file as vcd n svcd and in both case it said its not vcd compliant and its not svcd compliant and needs encoding cos so far i had known that mpeg is either vcd or svcd and we shud be able to burn either of 2 without encoding :S
pls guide me
https://www.videohelp.com/play.htm#identify
GSpot (latest Beta 2.52)
MediaInfo
Any others listed here:
https://www.videohelp.com/tools?s=38#38If in doubt, Google it. -
after doing test i got this
H:\movie01.MPG
File : 794 MB (1.08 GB), duration: 0:56:32, type: MPG, 1 audio stream(s), quality: 73 %
Video : 1023 MB, 2530 Kbps, 29.970 fps, 480*480 (1.0:1), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 90 MB, 224 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
what will be the easiest way to burn this without encoding etc ?
and how to learn a bit more about this result ive got -
That's XSVCD - 480 x 480 MPEG-2, bitrate under 2600kbps and 224kbps MP2 audio. It's the 48Khz audio that's not compliant.
Check out https://www.videohelp.com/dvd
Check out https://www.videohelp.com/vcd
Check out https://www.videohelp.com/svcd
Untick "Create Standard Compliant SVCD" tickbox in Nero and it should accept it without re-encoding it.If in doubt, Google it. -
This was a great help but this program doesnt understand NSV formated files.
Us there one that can tell me whether my NSV file was done in VP6 or VP8 format. This is important because i am currently converting from VP6 to VP8 for my video streams and i had a system crash and i dont know where the nsvate program left off
Where can I find 1080p HD video that isn't .wmv format?
By brassplyer in forum Latest Video NewsReplies: 7Last Post: 28th Jan 2011, 16:36 -
How to find out , what format a dvd recording is..
By jcazel in forum Newbie / General discussionsReplies: 8Last Post: 10th Dec 2010, 15:01 -
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 17:52 -
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
Find MMS for video?
By Jedi5 in forum Newbie / General discussionsReplies: 6Last Post: 10th Jan 2008, 22:07
