Hi, was wondering (since I need it for editing),
which models have firewire that works in both directions.
The master list indicated whether the unit 'has' firewire or not, but not if it can handle in and out.
And of the ones you can recommend which is best?
Cheers
Pioneer made the only ones that work both ways. The hard drive models are the DVR-510H-S and DVR-520H-S. The disc-only models are the DVR-310-S and DVR-320-S. One thing to note is that the video must be recorded to the hard drive or disc before it can be exported via the DV link. It doesn't do live pass-through of the incoming video signal the way a Canopus box does.
Can anyone confirm those models are capable of that, and any other DVD recorders with hdd that can transfer video from their hdd to pc via 1394 or USB2. Pref Pioneer.Originally Posted by Frobozz
Would the above method be quicker at transfering video to pc, compared to burning a DVD on the recorder from it's hdd, then placing that in the pc, and extracing the video that way, yes/no?
What kind of confirmation do you want? I've captured DV video via Firewire link to my Mac from my Pioneer DVR-510H's hard drive. It is a real-time transfer.
If you have a DV camcorder or an analog-to-DV converter you can do the same thing with any DVD recorder via the recorder's S-video and analog audio outputs.
I think the manuals for those models are still available for download at pioneerelectronics.com. You'll see that they describe the iLink (Firewire) as both DV in and DV out.
If it is on your recorder's hard drive, than a video should be in mpeg2 format, right?Originally Posted by Frobozz
Is it possible to transfer that mpeg2 to your Mac via Firewire link or the transfer goes in real time in DV (avi) format, only?
The source video must be MPEG encoded either on the HDD or on disc, and the output is DV only via Firewire. There isn't much benefit to this feature because of those limitations, but it does work and can be a time-saver compared with software conversion to DV on slower computers. Also, I was able to capture directly into iMovie. When doing a software DV conversion on the Mac I'd have complete the conversion and then import the DV video file to iMovie. This results in the DV video getting written a second time which is slow and requires twice the amount of hard drive space.Originally Posted by Jeremiah58
Also, DV import from the Pioneer isn't processor intensive for the Mac, as is software conversion.
Difference between these two Panasonic camcorder models
By jeanpave in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 5th Jul 2011, 16:11 -
Easycap models and quality?
By liran054 in forum CapturingReplies: 14Last Post: 14th Feb 2011, 04:19 -
What's the draw for the new 2010 models?
By oldfart13 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Feb 2010, 10:13 -
recent Lite-On models - what do their names mean?
By JohnnyBob in forum DVD & Blu-ray WritersReplies: 4Last Post: 29th Jul 2009, 13:02 -
Digital Betacam Models and Specs
By seb.tatut in forum Newbie / General discussionsReplies: 8Last Post: 7th May 2008, 14:24
