hi im new to this forum so i will say hi first lol
now i got a toshiba 27wl56 lcd tv hd ready and i want to connec this
http://www.divxtech.com./modix_hd3520.html
to my tv, but i want to use the coponent setup as i want to watch movies in hd and so component is better.
now this tv is conponent compatible but it doesnt have the rgb sockets instead it has Component video: Via PC Input socket. ie a min d sub 15p connector .
but if i use that with the component connector on the modix hd 3520 im going to have 6 rgb male connectors so its not going to work. can any advise me on teh best way to connect this piece of equipment to my tv to ge the best picture and hd quality
thanks for ya time
andy
Thread: cables?
The 15pin D is for a VGA computer connect. It won't work.Originally Posted by andyv12
You need analog component inputs for HD. Next best (SD) is S-video. Then composite.
Maybe someone from the UK knows if analog component YPbPr is supported over a 21-pin SCART. If not you are out of luck for HD connection.
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 00:17 -
Extension cables vs Replacement cables
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2011, 20:03 -
dv cables
By rizvi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Mar 2009, 02:44 -
dv cables help required
By rizvi in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 18th Mar 2009, 03:05 -
Are all SATA cables the same?
By spiffy in forum ComputerReplies: 4Last Post: 13th Nov 2007, 01:49
Statistics
Newest guides
Latest tool updates
New media comments
