VideoHelp.com Forum
    hi guys,
    the software i use to convert avi to dvd is SVCD2DVD.
    the divx movies i get come with a binary sub file but my software only supports text sup files.
    is there a way to make the binary sub file into a text sup file. Ive tried subtitle creator but that only handles text sub files.
    or is there a way that i can convert binary sub file to a text sub file which then i could use subtitle creator to make a sup file !!!
    cheers
    Sup files are bitmap based though, unless it is using a different kind of sup. Should be a tool called sub2sup or similar that can convert.
  3. Hi-
    ...but my software only supports text sup files.
    There's no such thing as a text based SUP file, as far as I know. Perhaps you mean a text based SUB file? And if so, then there are a number of apps that can OCR from IDX/SUB to text based SUB, among them Sub Resynch, which comes with the VobSub package.
    thanks guys, Ill double check my formats again
  1. FFMPEG Win32 binary
    By DEmberton in forum Programming
    Last Post: 1st May 2010, 09:59
  2. Replies: 1
    Last Post: 25th Feb 2010, 08:54
  3. Replies: 1
    Last Post: 2nd Feb 2010, 17:44
  4. Replies: 6
    Last Post: 27th Jun 2008, 10:38
  5. C# code to save text from listbox to a text file -- SOLVED--
    By freebird73717 in forum Programming
    Last Post: 2nd Sep 2007, 15:50
