VideoHelp.com Forum
Results 1 to 12 of 12
    I have been trying to extract specific title sets using MTR 2.6.6 and I'm having problems. While I am having no problems with main feature extraction. I follow the manual for title-chapter extraction by first selecting that extraction type, then setting the start chpt (SChpt) and then end chpt (EChpt) then I click go to extract. The extraction occurs but it won't allow playback. Can anyone help me with what I may be doing wrong or something I need to do in order to accomplish this ... any help is greatly appreciated!
    please stay in the mac forum section. moving you.
    I really like using yade X for chapter extraction since you get a preview of the exact scene you want.
    To do it in MTR though choose the Mode tab - Title - Chapter Extraction - and select the chapter you want - then hit GO!
    When doing this I end up with a .vob file that can be played in VLC/MPlayer.
    If it's a newer DVD with ARccOS you probably need the version 3 beta of MTR.
    live4ever ...
    I do exactly what you do except I get a single .vob file that won't play back. I get a prompt that states "There was a problem opening the media. The media type is not supported." Any suggestions on how to overcome this problem?
    Does it happen on every single DVD you try (try it on an older one, released in 2000)? Does the vob open in Mpeg Streamclip? If it doesn't work in MPlayer what does the error say?
    Playing /Users/Lee/Desktop/DVD_VIDEO Title 1 (Ch4 - Ch4)/VIDEO_TS/DVD_VIDEO Title 1 (Ch4 - Ch4).VOB.
    MPEG-PS file format detected.
    VIDEO:  MPEG2  720x480  (aspect 2)  29.970 fps  9800.0 kbps (1225.0 kbyte/s)
    Opening audio decoder: [liba52] AC3 decoding with liba52
    Using AltiVec optimized IMDCT transform
    AC3: 2.0 (stereo)  48000 Hz  192.0 kbit/s
    Checking for AltiVec resampler : 0x00000002, 2
    Using AltiVec optimized resampler
    AUDIO: 48000 Hz, 2 ch, s16be, 192.0 kbit/12.50% (ratio: 24000->192000)
    Selected audio codec: [a52] afm: liba52 (AC3-liba52)
    Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
    VDec: vo config request - 720 x 480 (preferred colorspace: Mpeg PES)
    Could not find matching colorspace - retrying with -vf scale...
    Opening video filter: [scale]
    The selected video_out device is incompatible with this codec.
    Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
    VDecoder init failed :(
    Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
    Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
    AO: [macosx] 48000Hz 2ch s16be (2 bytes per sample)
    Starting playback...
    VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    SwScaler: using unscaled Planar YV12 -> Packed YUY2 special converter
    VO: [macosx] 720x480 => 720x540 Packed YUY2
    A: 891.4 V: 891.4 A-V:  0.041 ct: -0.003  16/ 13 ??% ??% ??,?% 0 0
    demux_mpg: 24000/1001fps progressive NTSC content detected, switching framerate.
    A: 892.2 V: 892.2 A-V:  0.034 ct:  0.004  35/ 32 31% 12%  4.6% 0 0
      =====  PAUSE  =====
    That's what I got from MPlayer on my vob that works.
    Which DVD and which chapter are you trying to extract (I'll see if I have it to try)?
    Live4ever ...
    Yes it has happened to ever disc I have ever tried it with. To be more specific I'm trying to rip adult titles. I just tried the movie Friday, as you suggested doing a move before 2000, and I got the same results.
    Now I'm not even close to a computer expert so I don't really know what a Mpeg streamline is or what the Mplayer is? So since Quicktime plays Mpeg files I thought that was what you were talking abot and tried to get it to play back in the Quicktime application ... it didn't work ... it gives me a "Error opening movie ... The movie could not be opened" prompt. Now I assumed that the Mplayer is the Mac Application DVD Player ... when I tried to open the file in this appapplication it gave me a "There was a problem opening the media ... The media type is not supported" prompt.
    Do I need a different MTR application? I'm using version 2.6.6 ... maybe I have to change some of the preferences?
  7. Explorer Case's Avatar
    QuickTime Player standard will not playback VOB files, or any file with MPEG-2 video. If you install the $20 MPEG-2 component, then QuickTime Player will play the video, but the audio depends on which format: MP2 - audio; AC3 - no audio.
    MPlayer - movie player for MPEG-1/2/4, VOB & other formats, available as CLI (link) and GUI (link) app
    Apple DVD Player only plays from correctly authored VIDEO_TS folders
    VLC media player - movie player for MPEG-1/2/4, VOB & more
    MPEG Streamclip - convertor/editor for MPEG & transport streams (needs MPEG-2 component for VOBs; does full screen placyback)
    Case ...
    I just want to be able to play specific chapter extracted files in my Apple DVD Player. I can play main feature extracted file in my Apple DVD Player, but can't get it to play back when I do title set extraction.
    Case ...
  10. Explorer Case's Avatar
    Sizzle can author your single VOB file to a VIDEO_TS folder with IFO, BUP and VOB files. So do Toast and ffmpegX and I'm sure several other apps. I'd recommend Toast for simplicity, if you can use that.
    Case ...
    So you saying buy Toast and that will end my problem. I' m new to this extractiong stuff and what not so I don't always know the lingo. I know Toast is software that allows you to take Video_TS files and put them on to a DVD ... am I correct? That is ultimately what I'm trying to do ... take my extracted files main feature or chapter specific and put it on to a DVD R for play back in conventional DVD player.
  12. Explorer Case's Avatar
    Here's how I would process the extracted VOB file.
    Open Toast, set it to DVD-Video, with reencode to 'never'. Drop the VOB into the Toast window. Burn to disc, or save as disc image (in order to test it in Apple DVD Player first). Your VOB will be re-multiplexed by Toast in the authoring process. You can open the disc image file by double-clicking. Toast will then allow you to mount the disc image as a virtual DVD on the desktop. You'll see a familiar VIDEO_TS folder in there. When launching Apple DVD Player, it will notice the presence of the mounted DVD volume and starts playing. The same disc image can be used to burn, without going through the authoring process again.
  1. MKV chapter file extraction problems
    By ikarishinji41 in forum Editing
    Last Post: 22nd Mar 2010, 11:03
  2. VOB2MPG Chapter Extraction Problem
    By murray666 in forum SVCD2DVD & VOB2MPG
    Last Post: 20th Oct 2009, 03:14
  3. Replies: 3
    Last Post: 9th Aug 2009, 14:13
  4. Replies: 4
    Last Post: 15th Dec 2008, 11:51
  5. Pgcedit to go to main menu after a specific chapter?
    By redsandvb in forum DVD Ripping
    Last Post: 15th May 2008, 19:32
