What is truly the best Xvid/Divx to DVD Conversion program?
There are so many in both freeware or commerical. Looking through various programs mentioned on this website and forum, it seems to be at least 20+ different programs.
What are the real difference in actually conversion quality or etc?
Thread: Best Xvid/Dvix to DVD Program?
convertxtodvd is best.
Of the one-click-wonders the only one I would consider is ConvertXtoDVD. It is the most consistent - although not perfect - and does pretty much what it says it will. None of the other seem to deliver. There is a free version, called DivxtoDVD (it was an early development beta stage) which is good, but the pay version is much better again.
I haven't really tried any of the free alternatives like AVI2DVD or DIKO. I prefer to do it all manually, stage by stage. This means avisynth -> CCE (for Video encoding) -> SoundForge (for AC3 audio) -> DVD Lab Pro (for authoring) -> Prassi ONES (for burning). This gives me the best quality possible from the source material, and complete freedom over menu design. It takes a little longer to set up the first few times, but it soon becomes second nature.
Of course, by far the simplest solution is to get a Divx certified DVD player, then conversion becomes less of a necessity.
Program for converting DVD to Xvid with 3 audio tracks ?
By Noahtuck in forum Video ConversionReplies: 2Last Post: 27th Jun 2010, 00:17 -
dvix/xvid to dvd using ffmpegx???
By Jgarlich in forum ffmpegX general discussionReplies: 2Last Post: 20th Jul 2009, 20:57 -
A DVD recorder with a USB Direct connection that allows Dvix and Xvid
By Conercao in forum DVD & Blu-ray RecordersReplies: 9Last Post: 6th Dec 2008, 12:22 -
Sound Problem During Playback (XVid, DVIX etc.)
By Pyrolisk in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 11:00 -
Can anyone recommend at good program for converting DVD to Divx or Xvid?
By gbgunner in forum DVD RippingReplies: 13Last Post: 10th Nov 2007, 17:18
Statistics
Newest guides
Latest tool updates
New media comments
