VideoHelp.com Forum
    I am a newbie, and I recently ripped a DVD move to MPEG1, then created a Video CD with Roxio CD Creator 5.0 with the help of this site. If I insert the CD in a computer, it works with WINDVD but will not play in my Sony DVD Player. Can anyone give me advice on what I may be doing wrong?
    Keith
  2. nothing...Sony are notoriously strict for not playing VCDs on CDRs, A) Check to make absolutely sure your DVD player supports VCDs B) Try using a CDRW instead, the Sonys that do play VCDs tend have better success from CDRWs
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Thanks for your comments on using s CDRW instead of a CDR.
    I created a new CDRW with Roxio, and the Sony DVD player can see the CD now, and knows it is a picture CD, but displays an error when trying to play it.
    I wonder what would be a good DVD Player to replace the Sony with where I won't have any compatibility issues in the future from burning. The only reason I have a Sony, is all my components are from Sony. TV, Receiver, VHS, CD Juke Box, etc. So I have one remote that works with everything.
    Thanks again for your help,
    Keith
  4. There are Sony models out there that play VCDs fine...you just have to check the compability list to your left..or Sony's web site.
  1. My Sony CD/DVD player (NS55P) would almost only play sony discs.
    By valdes001 in forum DVD & Blu-ray Players
    Last Post: 30th Jan 2011, 10:03
  2. downloaded video wont play in my dvd player
    By KingRich70 in forum Newbie / General discussions
    Last Post: 10th Jan 2011, 18:52
  3. Cannot play Zone 1 disc on my Sony dvp-sr100 DVD player
    By lea in forum DVD & Blu-ray Players
    Last Post: 23rd Apr 2010, 13:24
  4. Can't play MP3s on my Sony DVP NS355 DVD player
    By harrylentil in forum DVD & Blu-ray Players
    Last Post: 6th Aug 2009, 14:04
  5. Would i be able to play a pal dvd with a sony blu ray player
    By fceurich in forum DVD & Blu-ray Players
    Last Post: 7th Feb 2008, 09:47
