I recently purchased a JVC DR-MH30 DVD recorder. I hooked my Direct TV satellite receiver through the DVD's L-1 inputs. That works fine; video and audio signals gets recorded, and the audio/video comes from the output through the TV.
But when I try to connect either my VCR or analog cassette recorder through the L-2 or F-1 stereo inputs of the DVD recorder, nothing comes through the any of the outputs or is recorded. I want to record onto DVD disc some home audio-only cassette recordings, and some home video recordings. But I cannot figure out the correct way to connect the components, I guess. (Or is there some internal anti-copying device preventing me from doing this?) I'm a novice at all this, mind you.
I tried stereo RCAs from the cassette decks out to the DVD's L-2 input and got nothing. Same with the VCR's output to the DVD's L-2 or F-1 inputs. Nada.
Thread: JVC DR-MH30 Hook-Up Question
Did you select the L2 input as the one from which you want to record? The recorder does not sense which input has a signal. It is manually selected.
Yes. I tried selecting L2, using the channel selector on the remote.
try hooking your direct tv cable to the(in) on your vcr..then connect a cable to the (out) on your vcr to the (in) on your recorder..then connect a cable from the (out) on your recorder to your tv..it worked for me..
Need suggestions on JVC DR-MH30
By iamnotamused in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Sep 2010, 02:04 -
Artefacts in recoverd MPG files from JVC DR-MH30
By PGottfried in forum ComputerReplies: 3Last Post: 31st Jan 2010, 21:10 -
JVC DR-MH30 make or restore hd particion
By danilo_nop in forum DVD & Blu-ray RecordersReplies: 0Last Post: 29th Feb 2008, 03:01 -
JVC DR-MH30 Broke I Think Update.
By hutch642 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Dec 2007, 08:43 -
JVC 9911 SVHS to MH30 - audio
By quickpick in forum RestorationReplies: 1Last Post: 6th Aug 2007, 11:45
Statistics
Newest guides
Latest tool updates
New media comments
