I use Adobe Premiere Pro 1.5. Prior to this I was using Pinnacle 10.5 for my capturing purposes with my internal ATI 9600 ALL-IN-WONDER 2006 card. The said card is not compatible with my APP 1.5. It captures ok with the Pinnacle program, but I really don't use this editing program anymore as I prefer Premiere. I want to remove Pinnacle from my drive to free up space. I don't want to use Windows Movie Maker for capture because of the outputted file type. What video capture application is out there that would work? Thanks in advance. Michael
Thread: video capture application
Use the ATI MMC that came with the card. See www.digitalfaq.com for everything you need to know about capturing with ATI cards.
Try Scenalyzer Live (http://scenalyzer.com/). It was a FINAL solution to me.
Good luck
Only the ATI-MMC will get you the realtime AIW MPeg encoding modes. If you are capturing uncompressed, most capture programs will see the AIW. VirtualDub sees my AIW.
[SOLVED] Application to combine video + sound tracks?
By yetanotherlogin in forum Newbie / General discussionsReplies: 15Last Post: 22nd Apr 2012, 17:38 -
Is there really no application that can ripp/save this video ?
By harry88 in forum Video StreamingReplies: 4Last Post: 5th Mar 2012, 12:05 -
Best capture application Mac
By wahsac in forum MacReplies: 13Last Post: 4th Oct 2009, 15:50 -
Video Browser/Thumbnail Application?
By Martin J. in forum Software PlayingReplies: 2Last Post: 30th Jun 2009, 18:53 -
winfastpvr application/ Capture Format problem
By bibimaryam in forum Newbie / General discussionsReplies: 6Last Post: 28th Apr 2009, 08:57
Statistics
Newest guides
Latest tool updates
New media comments
