Found this Seagate 500GB drive for $190 http://shop2.outpost.com/product/4795159#detailed What is PATA? And would it work in my PC or in any external enclosure?
What We Do In Life, Echoes In Eternity....
PATA is just IDE/EIDE, renamed slightly to match SATA.
PATA is ATA parallel which is the most commonly used type for hard drives. It plugs into your IDE controllers on the mobo. If you want to use a external enclosure it has to be one that is ATA parallel. If you want to use it in your pc you need to have a ide controller available. most mobos have 2 IDE controllers. if all of them are taken you can always buy a PCI CONTROLLER CARD for the PATA hard drive. SATA hard drives supposedly are faster that PATA but not by too much. those are good for conducting better air flow in your computer case because the cables are thinner than the flat ide cables.
HP Pavilion dm1 and Sony Bravia
By christinaki19 in forum ComputerReplies: 6Last Post: 27th Nov 2010, 16:04 -
Will my HP Pavilion a6220n work as a HTPC/server?
By zeek543 in forum Media Center PC / MediaCentersReplies: 4Last Post: 27th Dec 2009, 22:26 -
lightscribe drive question HP Pavilion DV6000Z
By cduval04 in forum DVD & Blu-ray WritersReplies: 1Last Post: 11th May 2008, 04:15 -
evolving my hardware...pata + sata?
By bgd73 in forum ComputerReplies: 8Last Post: 1st Apr 2008, 11:37 -
Where to buy a restore disc ro an HP Pavilion 7955?
By Denvers Dawgs in forum ComputerReplies: 6Last Post: 30th Jul 2007, 23:54
Statistics
Newest guides
Latest tool updates
New media comments
