VideoHelp.com Forum
    Version 12.06.18.15. Get it here .
    As far as I can tell, the only change is the addition of Cyrillic Divx subs.
    dg.
  2. I have a DVP-5140/37 Will this firmware also work?
  3. Member ntngod's Avatar
    I'm staying away, for now.
    That version number seems quite a bit different from what the 5140/37 are shipping with.
    My 5140/37's firmware screen
  4. Member ntngod's Avatar
    EDIT: I'm a moron. The first number is the revision (12 or 37). That's what I get for posting while eating 8) Too many of my brain cells were occupied with the 'lift fork to mouth' process, apparantly.
    So it's 06.18.15 vs. 06.19.07.
    Hmm.. I'm undecided if I'll try it.
    Here's how my original version screen looked:
    VERSION: 12.06.18.12
    SUB-VER: 00.00.06.05
    8032: 05.00.04.02
    SERVO: A8.58.30.00
    RISC: 05.00.04.02
    DSP: 03.02.02.54
    REGION: 2
    This is after the upgrade (changes are underlined):
    VERSION: 12.06.18.15
    SUB-VER: 00.00.06.06
    8032: 05.00.04.02
    SERVO: A8.58.30.00
    RISC: 05.00.04.02
    DSP: 03.02.02.54
    REGION: 2
    @ ytsejam & ntngod:
    If I were you I will stay clear of this one, at least till you know more about it. You will gain Cyrillic subs which you probably don't need but for one thing, you will loose the closed caption option (which 12 models don't have) and you will have to hack the region.
    dg
  6. Member ntngod's Avatar
    So the update changes the /12's SUB-VER to what the /37 already ships with....
    Actually, considering the North American model is a presumably a couple of months newer than the overseas version (since we just started getting it here), that would make some sense that the North American stock firmware would be newer (if that is indeed the case). Philips had more time to slap a newer firmware in there.
    Version 17 (12.06.18.17) is out.
    download here .
    BTW, I've had problems burning a working CD for flashing, until I renamed the original binary to "DVP5140_12.BIN" (without quotes). I might be wrong but I think the drive didn't like the space and/or the lower case extension in the original file name.
    dg.
  1. My Philips DVP 5140 has an annoying echo sound
    By Amuse in forum DVD & Blu-ray Players
    Last Post: 26th Sep 2008, 10:55
  2. Philips DVP 5140 or DVP 642/37, which is better?
    Last Post: 2nd Feb 2008, 16:26
  3. sound but no pic w/Philips 5140 + HDTV avis
    By ezu0526 in forum DVD & Blu-ray Players
    Last Post: 22nd Aug 2007, 21:52
  4. sleep does nothing to a philips 5140
    By BirdDaddie in forum DVD & Blu-ray Players
    Last Post: 22nd Jun 2007, 16:52
  5. Philips 5140, Xvid & Subtitles
    By Madz in forum Subtitle
    Last Post: 18th May 2007, 03:13
