Subject says it all.
Happens every time.
Mac: Intel iMac 2GHz, 512MB RAM, 10.4.6, QT 7.1. Otherwise, everything works fine.
Crash dialog attached as a jpeg.
Here's the crashlog:
Host Name: barry-levines-computer
Date/Time: 2006-05-25 16:44:37.437 -0600
OS Version: 10.4.6 (Build 8I1119)
Report Version: 4
Command: mplayer
Path: /Library/Application Support/ffmpegX/mplayer
Parent: ffmpegX [314]
Version: ??? (???)
PID: 342
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_INVALID_ADDRESS (0x0001) at 0xb9005c8c
Thread 0 Crashed:
0 libobjc.A.dylib 0x90a4e387 objc_msgSend + 23
Thread 1:
0 libSystem.B.dylib 0x9000a4e7 mach_msg_trap + 7
1 com.apple.CoreFoundation 0x9082369a CFRunLoopRunSpecific + 2014
2 com.apple.CoreFoundation 0x90822eb5 CFRunLoopRunInMode + 61
3 com.apple.audio.CoreAudio 0x914549f2 HALRunLoop::OwnThread(void*) + 158
4 com.apple.audio.CoreAudio 0x9145480d CAPThread::Entry(CAPThread*) + 93
5 libSystem.B.dylib 0x90024a27 _pthread_body + 84
Thread 2:
0 libSystem.B.dylib 0x90049207 semaphore_timedwait_signal_trap + 7
1 com.apple.audio.CoreAudio 0x91461af8 CAGuard::WaitFor(unsigned long long) + 212
2 com.apple.audio.CoreAudio 0x91461a1a CAGuard::WaitUntil(unsigned long long) + 66
3 com.apple.audio.CoreAudio 0x9146048a HP_IOThread::WorkLoop() + 690
4 com.apple.audio.CoreAudio 0x914601d1 HP_IOThread::ThreadEntry(HP_IOThread*) + 17
5 com.apple.audio.CoreAudio 0x9145480d CAPThread::Entry(CAPThread*) + 93
6 libSystem.B.dylib 0x90024a27 _pthread_body + 84
Thread 0 crashed with i386 Thread State:
eax: 0xb9005c8c ebx: 0x92704672 ecx:0x90ab4fd0 edx: 0x00000069
edi: 0xb9005c94 esi: 0xbfffe8d8 ebp:0xbfffe968 esp: 0xbfffe8a4
ss: 0x0000002f efl: 0x00010206 eip:0x90a4e387 cs: 0x00000027
ds: 0x0000002f es: 0x0000002f fs:0x00000000 gs: 0x00000037
Binary Images Description:
0x1000 - 0x7b0fff mplayer /Library/Application Support/ffmpegX/mplayer
0xf4b000 - 0xf67fff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
0xf6e000 - 0xf8efff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x1316a000 - 0x13290fff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x132b8000 - 0x134adfff com.apple.ATIRadeonX1000GLDriver 1.4.26 (4.2.6) /System/Library/Extensions/ATIRadeonX1000GLDriver.bundle/Contents/MacOS/ATIRadeonX1000GLDriver
0x13aa7000 - 0x13af7fff com.DivXInc.DivXDecoder 6.0.5 /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
0x70000000 - 0x70105fff com.apple.audio.units.Components 1.4.2 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8ebca000 - 0x8f77cfff com.apple.QuickTimeComponents.component 7.1 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x8fabb000 - 0x8fd72fff com.apple.QuickTime 7.1.0 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x8fe00000 - 0x8fe4bfff dyld 44.17 /usr/lib/dyld
0x90000000 - 0x9016efff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901be000 - 0x901c0fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x901c2000 - 0x901fefff com.apple.CoreText 1.1.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90225000 - 0x902fafff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9031a000 - 0x9076afff com.apple.CoreGraphics 1.258.30 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90801000 - 0x908c9fff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x90907000 - 0x90907fff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90909000 - 0x909fcfff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a4c000 - 0x90acbfff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90af4000 - 0x90b57fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x90bc6000 - 0x90bcdfff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x90bd2000 - 0x90c42fff com.apple.framework.IOKit 1.4.2 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90c57000 - 0x90c69fff libauto.dylib /usr/lib/libauto.dylib
0x90c6f000 - 0x90f14fff com.apple.CoreServices.CarbonCore 682.10 (679) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90f57000 - 0x90fbffff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90ff7000 - 0x91035fff com.apple.CFNetwork 129.16 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91047000 - 0x91057fff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91062000 - 0x910e0fff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91115000 - 0x91133fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9113f000 - 0x9114dfff libz.1.dylib /usr/lib/libz.1.dylib
0x91150000 - 0x91303fff com.apple.security 4.2.1 (24989) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913f1000 - 0x913f9fff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91400000 - 0x91426fff com.apple.SystemConfiguration 1.8.5 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91438000 - 0x9143ffff libbsm.dylib /usr/lib/libbsm.dylib
0x91443000 - 0x914bcfff com.apple.audio.CoreAudio 3.0.3 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9150a000 - 0x9150afff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9150c000 - 0x91537fff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9154a000 - 0x9161efff com.apple.ColorSync 4.4.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91657000 - 0x916d4fff com.apple.print.framework.PrintCore 4.5 (177.10) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91701000 - 0x917abfff com.apple.QD 3.10.9 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917d1000 - 0x9181cfff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9183b000 - 0x91851fff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9185d000 - 0x91877fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x91881000 - 0x918befff com.apple.LaunchServices 178 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x918d2000 - 0x918ddfff com.apple.speech.synthesis.framework 3.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918e4000 - 0x9191bfff com.apple.ImageIO.framework 1.4.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9192d000 - 0x919dffff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91a25000 - 0x91a3bfff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91a40000 - 0x91a5cfff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91a61000 - 0x91abffff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91acf000 - 0x91ad3fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91ad5000 - 0x91b30fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91b34000 - 0x91b71fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91b77000 - 0x91b91fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91b96000 - 0x91b98fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91b9a000 - 0x91b9afff com.apple.Accelerate 1.2.1 (Accelerate 1.2.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91b9c000 - 0x91c22fff com.apple.vImage 2.3 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91c29000 - 0x91c29fff com.apple.Accelerate.vecLib 3.2.1 (vecLib 3.2.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91c2b000 - 0x91c70fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91c78000 - 0x91c9dfff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91ca4000 - 0x92227fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x92264000 - 0x92616fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92643000 - 0x926c7fff com.apple.DesktopServices 1.3.3 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92703000 - 0x92935fff com.apple.Foundation 6.4.5 (567.26) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92a41000 - 0x92b1ffff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92b3c000 - 0x92c29fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92c39000 - 0x92c50fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92c5b000 - 0x92cb2fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92cc6000 - 0x92cc6fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92cc8000 - 0x92cd8fff com.apple.ImageCapture 3.0.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92ce6000 - 0x92ceefff com.apple.speech.recognition.framework 3.5 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92cf4000 - 0x92cf9fff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92cff000 - 0x92d90fff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92da4000 - 0x92da7fff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92daa000 - 0x92dc7fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92dd7000 - 0x92dddfff com.apple.print.framework.Print 5.1 (192.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92de3000 - 0x92e46fff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92e6a000 - 0x92eabfff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92ed2000 - 0x92edffff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92ee6000 - 0x92eebfff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92ef0000 - 0x931e2fff com.apple.HIToolbox 1.4.6 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x932e7000 - 0x932f2fff com.apple.opengl 1.4.9 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93361000 - 0x93361fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93363000 - 0x93a1cfff com.apple.AppKit 6.4.6 (824.39) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93d9d000 - 0x93e17fff com.apple.CoreData 90 /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93e50000 - 0x93f10fff com.apple.audio.toolbox.AudioToolbox 1.4.2 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93f4f000 - 0x93f4ffff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93f51000 - 0x940fffff com.apple.QuartzCore 1.4.7 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9414d000 - 0x9418efff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x94196000 - 0x941cffff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9434a000 - 0x94359fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x94360000 - 0x9436bfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x943b7000 - 0x943d1fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x95773000 - 0x957a1fff libncurses.5.4.dylib /usr/lib/libncurses.5.4.dylib
0x961d8000 - 0x961d8fff com.apple.vecLib 3.2.1 (vecLib 3.2.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x96748000 - 0x96803fff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9681d000 - 0x9681efff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
0x96820000 - 0x96825fff com.apple.agl 2.5.9 (AGL-2.5.9) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
Results 1 to 1 of 1
Qt + Mac OS X + mplayer embedding,...
By Selur in forum ProgrammingReplies: 0Last Post: 23rd Apr 2012, 13:22 -
Mplayer as an *encoder*?
By RogerTango in forum Video ConversionReplies: 5Last Post: 31st Jan 2010, 10:59 -
mplayer freeze
By ajv in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 16:15 -
Trouble with MPlayer and subtitles
By guitarscn in forum Software PlayingReplies: 2Last Post: 29th Apr 2008, 01:53 -
mencoder and mplayer packages
By mattr in forum ffmpegX general discussionReplies: 1Last Post: 30th Dec 2007, 08:05
