I've really tried every tool I can find, read many posts, installed tons of codecs, and I'm starting to go a bit crazy.
Here's the mission.
I've got an MKV movie (anime...) that I'm trying to get into a format I can play on my PSP. I've had success with this sites help in getting several OGM files working using VirtualDubMod (even got subtitles working with the VobSub, TextSub Filter). Converting to MP4 with subtitles and Japanese language is the ultimate goal.
Anyway, I can Extract all of the Audio and Subtitles with mkvextract. That's working okay.
It's the Video portion that's giving me fits.
According to an MKVinfo utility, it's using a V_MPEG4/ISO/AVC codec.
The latest version of mkvextract extracts it successfully, but creates a raw avc stream.
avc2avi converts to avi succesfully, but when attempted to load into VirtualDubMod, it still fails due to H264 encoding.
I'm supposing I need a program that can decode the AVI I have now, then re-encode with a codec that VirtualDubMod will work with. My last step is using ImToo Encoder which has a nice preset converter to MP4 with settings that work nice for the PSP.
Any help is greatly appreciated... much thanks in advance.
-Sylus
Thread: An MKV Conversion Problem
"Watch the Weather Change..."
You need to have ffdshow installed and enabled to decode AVC. Easier I think to just convert the mkv directly.
Problem conserving 5.1 from MKV conversion
By l'ensemble in forum MacReplies: 1Last Post: 24th Jan 2011, 14:35 -
Problem on MKV Conversion. Please help.
By maicans in forum Video ConversionReplies: 2Last Post: 11th Jun 2010, 11:17 -
Problem with mkv to DVD conversion
By LoafingOaf in forum ffmpegX general discussionReplies: 0Last Post: 27th Oct 2009, 06:46 -
.ts to mkv conversion problem
By txl in forum Blu-ray RippingReplies: 1Last Post: 15th Sep 2009, 05:19 -
aimersoft mkv conversion problem...
By freewheelin in forum Video ConversionReplies: 1Last Post: 6th Sep 2009, 13:22
Statistics
Newest guides
Latest tool updates
New media comments
