  1. I downloaded a small file called: .asx (suffix)
    what is it? can I play it on a Mac? the icon is WMV but I guess my amc just guess that.
    cheers
    and Thanks rotut
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    .asx is a windowx media file. Download Windows Media Player to play it. http://www.microsoft.com/mac/otherproducts/otherproducts.aspx?pid=windowsmedia
  3. thanks I have WMV 9 and when I open the file WMV says: the specified stream type is not recognized.
    any ideas?
    cheers again.
    rotut
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    ASX files, as I recall, are just placeholders - they reference a streaming media file, usually online. If you load the ASX file in a text viewer/editor, you'll probably see the stream link (most likely beginning with 'mms:')
    One problem, though, is that the Mac version of Media Player hasn't been updated in some time (and has more or less been abandoned by Microsoft), so it doesn't handle some of the newer Windows Media formats (and therefore streams). Installing the Flip4Mac WMV component might help with viewing the stream, and VLC or mplayer might also be able to view the stream directly (well, I don't remember if you can call streams directly using mplayer...)
