hello, i need to know how i can delete the audio(track?) from a video file then add the edited audio back? ,here is what i did i used "goldwave" to exract mpg audio from video then "re-did/edited"" the same audio ,now i want to add the new"edited" audio to the same video ,but delete the "old" audio.i want to burn it to a standard dvd. the tools i am using/used , i used virtual dub to capture,Tmpgenc to encode/compress, goldwave to "edit' the audio and use nero burning rom to "burn it" to dvd. any info would be great.thanx in advance.![]()
Hi-
So it's a DVD now, and you want to replace the audio? If so, put it back onto the hard drive using Drag-And-Drop or DVD Decrypter or whatever. Demux with PGCEdit, making sure to get the video. When done you'll have audio, video, celltimes.txt (with chapters, if any), and a SUP file or several for the subs (if any).
Reauthor using Muxman, replacing the old audio with the new audio. If there's no menu, then you're done. If there's a menu and maybe other stuff, then open the original DVD in VobBlanker and highlight the video you're working on. It'll show up in the lower screen. Highlight it in the lower screen and hit the "Replace" button to the right. Scroll to the DVD with the new audio and give it a destination. Hit "Process", wait a few minutes, and test it out.
Add audio won't work in audio menu.
By petwes in forum AudioReplies: 0Last Post: 21st Jan 2012, 07:59 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / HDTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
mp4's edited (merged) but audio out of sync
By stiltsky in forum EditingReplies: 2Last Post: 15th Sep 2010, 09:41 -
Encoded audio is not good - Add better audio?
By NotSoEasy in forum Video ConversionReplies: 2Last Post: 7th Feb 2008, 19:05 -
Trying to sync audio with edited video, problems with encode....
By Jensen in forum EditingReplies: 1Last Post: 5th Jan 2008, 08:20
Statistics
Newest guides
Latest tool updates
New media comments
