I'm trying to install proper drivers for a raid controller. It detects and boots into windows fine, but when I try to reinstall winxp it can't find the drive. I just assumed I need a new raid controller driver, I looked everywhere and still can't find one. The board I'm using is an Asus p4p8x.
Thread: Sata
When Windows XP is in it's hardware setup mode, Press F8 to install third party drivers. You should see a screen which says this at the bottom.
F6, not F8. There should be a utlity on the SATA Card CD to make a floppy for a Windows install.
Similar situation here:
http://forum.videohelp.com/viewtopic.php?t=264825
Start reading from "You'll be needing a healthy PC for this part." - it should explain the process for you.
Make sure your BIOS is set up correctly, that the RAID controller is set to the right mode (ie. RAID for two drives on a RAID array or IDE Mode for a single drive or several individual drives).
SATA 6.0 vs. SATA 3.0
By DarrellS in forum ComputerReplies: 7Last Post: 28th May 2011, 02:33 -
how to re-anable my sata icon in win xp sp3 (sata drives not visible in DM)
By deejay.2001 in forum ComputerReplies: 7Last Post: 11th Mar 2011, 09:47 -
SATA I cables and SATA II
By HatchetMan in forum ComputerReplies: 5Last Post: 4th Feb 2008, 15:06 -
Are all SATA cables the same?
By spiffy in forum ComputerReplies: 4Last Post: 13th Nov 2007, 01:49 -
Best SATA drive?
By shyamt in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Aug 2007, 13:08
Statistics
Newest guides
Latest tool updates
New media comments
