i used MediaInfo.
the audiostream is A_AAC/MPEG4/LC/SBR.
i have mkv pack installed, so i can play the video and audio properly, i can switch between 2 languages.
but when i load it into VirtualDubMod, i try to extract the audio stream, (full processing mode, PCM uncompressed), i get this: "No audio decompressor could be found........."
what else do i need to install?
There are no ACM aac decompressors since ACM is baaad. Use something else such as mplayer to decode.
problem solved, i used mkvextract to extract the audio into .aac
then used Nero's file encoder to convert to WAV.
Make sure that it recognised and decoded the SBR part. Some decoders don't for raw aac streams since there is no header marking it as such.
How to extract .srt from mkv file
By Wooody in forum SubtitleReplies: 11Last Post: 30th Apr 2011, 00:51 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 18:57 -
How can I extract hardsub from MKV. file
By Rippl in forum SubtitleReplies: 12Last Post: 7th May 2009, 14:00 -
extract subtitle from mkv file
By py52126 in forum SubtitleReplies: 1Last Post: 4th Feb 2009, 17:01 -
Is it possible to extract audio from a non MKV file?
By mvgc3 in forum Video ConversionReplies: 13Last Post: 2nd Apr 2008, 01:09
Statistics
Newest guides
Latest tool updates
New media comments
