VideoHelp.com Forum
Results 1 to 14 of 14
  1. Member terryj's Avatar
    been away from the whole need to rip and compress scene...
    so is DVD2OneX v2.05 worth the upgrade cost over
    just using Toast 7/Popcorn?
    I still have DTOX 1.42, but since
    I haven't had a need for it in my self-authoring
    ( I just use a BitRAte Calc and shrink accordingly),
    I was just curious what you guys thought....?
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  2. Member terryj's Avatar
    geez, NOBODY has made the jump yet?
    Urban Mac User
    Terry, I tried DTOX (1.4) once. Backing up "Capote," which
    was a resistant bugger that seemed to require a main-feature
    extraction and manually de-selecting blank cells. I thought it
    a nuisance at the time.
    For normal use I prefer the ease and sort-of user friendliness
    of Toast 7.
    My 2p.
  4. Member terryj's Avatar
    thanks, al.
    Urban Mac User
  5. Master of my domain thoughton's Avatar
    Hi terry, I presume from the DTOX 2.05 reference you are referring to Intel macs. I'll let you know in about 14 days when my new 17" MBP arrives!
    Tim Houghton
    WebsitePhotography
  6. If you have toast 7 and DETOX 1.4.2, i would see no reason to upgrade to the new DETOX, i have used it but the burning part of it is hit or miss with me so i still burn with toast.
    Sometimes I doubt your commitment to Sparkle Motion.
  7. Member terryj's Avatar
    thoughton...i'd be interested in hearing your reports.
    Me, I'm eyeing the Black MacBook for X-mas.....!
    Buick,
    so then I would assume from your post
    that edvberg didn't get my last hints
    that Popcorn was making DTOX obsolete
    by all the reports that Popcorn
    was handling newer ArCCos/Ripguard schemes
    better than (any version of DTOX after 1.42?)
    and didn't fix anything? This I posted to him,
    after initial reports of Toast 7.02's release...
    (for those who don't know, edvberg is one of the minds
    behnd DTOX)
    If so they should be ashamed charging for it ,
    if it lacks competitive functionality.
    Urban Mac User
  8. Master of my domain thoughton's Avatar
    DVD2OneX took 11 minutes to compress a 7.1GB video_ts folder. A lot better than the 1 hour it used to take!
    Tim Houghton
    WebsitePhotography
  9. Member terryj's Avatar
    Urban Mac User
  10. In terms of custom shrinking, do they have the same feature options? Last time I looked at doing it with Toast 7 or Popcorn 2, something about them just gave me the poops.
  11. I will update my post from above, i have found that having several tools works best. Some on the newer ripgaurd type DVD's you need the newest version of DETOX to handle them. I have been using DL Disc some lately and i like the ease of use Toast 7 offers on these, i also use Toast 7 when all i need is a small amount of compression. For compression over 25% i use DETOX and then toast 7 to burn.
    i use toast 7 until it gives me an error, then i'll switch to dtox 1.4.2...the latest version of dtox has an over simplified interface which i don't like at all...
  14. Master of my domain thoughton's Avatar
    Gotta agree with pixel, I don't like the new dvd2oneX interface at all. It took me a quite a while just to figure out how to make it stop burning automatically! On several occasions I've come back after a dvd2onex burn to find an error message about the burn. However the DVD appears to work okay. At other times it has failed halfway through a burn resulting in a coaster. Not very reliable, so I've gone back to shrinking with dvd2onex and burning with Toast.
    Tim Houghton
    WebsitePhotography
  1. Replies: 20
    Last Post: 14th Jul 2009, 22:16
  2. Best Software (IYO) For HD-DVD Playback
    By greymalkin in forum Media Center PC / MediaCenters
    Last Post: 3rd Mar 2009, 14:50
  3. Popcorn Hour
    By TheRubster in forum Newbie / General discussions
    Last Post: 13th Nov 2008, 15:10
  4. ffmpegX and Popcorn 2/Toast 6 (Light)
    By charliel52 in forum ffmpegX bugs and suggestions
    Last Post: 30th Aug 2008, 14:10
  5. Replies: 7
    Last Post: 17th Mar 2008, 12:27
