Hi,
I started to see sync'ing problem on my Sony camcorder and had the camcorder head serviced. Now, the tapes that I recorded a year or so do not play back (they did before servicing) on this camcorder or even on a new camcorder. There're a lot of jittering, jumping, color shift, and audio either drops or barely audible.
I figure the tapes had been recorded and played back OK with the bad head before the servicing, and should be easy to fix to resync, well, how wrong. I've tried the video restoration services, as well as tried to clean up with hardware TBC (Datavideo TBC-1000) with no success.
Please help if you have any suggestions, either some solutions or referring to some restoration place for this. The tapes are from kids' birthdays and such occasions and we just hate to lose all the memory.
Thanks in advance
pkn25
If only the head was changed, you have a warranty claim.
If you also requested a tape path alignment to standard, then all the tapes that were recorded while your camcorder was out of standard won't play correctly.
Proper playback requires the same misalignment that was present when the recording was made.
A good camcorder tech can misalign the deck to play yours well. You need to negotiate a two step deal. Misadjust until old tapes are transferred then set it right.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
edDV
Made a powerful point here...
This maybe the underlying reason for many many previously unexplained differences in VCR's and camcorders..
Everyone knows new VCR/camcorders should be factory calibrated to the VHS standard ..This requires accurate electronic calibration, and just as important mechanical calibration..Lower cost machines may bypass some of the calibrations and even worse, a machine can slowly drift out of calibration with use..Tape guides wear,heads wear,tape tensions change,stresses on some plastic parts change dimensions etc..We are talking microns not inches or milimeters in some cases..
please remember this was the "state of the art" back in the earlier days..Nobody could afford a Ampex machine in their living room but could afford 1000 bucks of so for a Betamax or VHS..
anyway, edDV hit it right on the head..Once a tape is recorded with an out of standard machine
then another machine may not play back correctly..
Sorry to rant on but I thought this should not be passed over lightly..
jolphil
The pro's have the same issues with the expensive machines but invest in frequent transport alignment calibrations to keep tapes interchangable.Originally Posted by jolphil
The typical consumer, me included
allow the machine to drift out of calibration until it has serious playback problems. Only then do we take it in for service. When the machine comes back, pre-recorded and early tapes play fine but recent ones don't.
Hello
I have a Sony EV-C400E Hi8 player and I suddenly get snow and image jumping ... what can I do?
My first guess is the heads are dirty. Use a cleaning tape.Originally Posted by marklewis
If that doesn't work take it in to the shop for a cleaning and alignment. The tech will suggest parts replacement if necessary.Recommends: Kiva.org - Loans that change lives.
Did you try a tracking adjustment? You push certain buttons to change it. Look at your manual.
Where to Repair Sony 9850 Hi8 deck and does it eliminate head switch glitch
By elandy in forum RestorationReplies: 7Last Post: 9th Mar 2011, 11:11 -
Dirty Head or Degrading Tape?
By nazopo in forum CapturingReplies: 7Last Post: 7th Aug 2010, 22:50 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD)Replies: 16Last Post: 22nd May 2009, 22:06 -
Mysterious problem with hi8 tape playback!
By cecile in forum CapturingReplies: 6Last Post: 12th Mar 2009, 18:18 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum CapturingReplies: 8Last Post: 22nd Dec 2007, 01:11
