Does any one know how I can convert any video files to AMV files ?? Thanks for the help
Results 1 to 11 of 11
Thread: Convert to AMV format
Here's some instructions: http://www.mympxplayer.com/dload.php...le&file_id=118
And a link to the converter: http://www.neonumeric.com/download_en.html
I have no idea if it will work, but it's the only reference I could find.
You can also check out: www.MyMPxPlayer.org as well. This also has the AMV Convert Tool (which is needed to convert video files to .amv).
Hope that helps.
Originally Posted by redwudz
softpedia.com or downloadatoz.com
try amv video converter its freeware.
Hi this business of the converstion of AMV format for Chinese players is really easy. Just download the AVIconverter make sure you get the correct picture size then follow instructions really easy. Not all the AVI converters have the sizes you may need so type in your search engine. <AVIconverter for 220X176> adding you own size. Niel
Try this tool amv-codec-tools http://code.google.com/p/amv-codec-tools/
What player do you have ?
The AMV version of ffmpeg does work, but not all players will accept it's output. I know the player my daughter has will only accept videos created with the it came with. I would suggest you start there.
good day guys....definitely converting any video file to AMV format is very easy.....just wondering has anyone found a good program to do exactly the opposite..? i mean convert an AMV video file to any format (avi, mpeg, wmv...etc)....?
any info will be appreciated..,,,been searching for decades but unable to find any....!
Hi, Friends.
Thank's to all of you.
You all have suggested very good links that all may be useful to me. I like to collect such type of informations as a data for use.
Thanks.
One way you can get free conveters is to go to download.com and search for amv converter. I think there is four or five to choose from.
http://home.netvigator.com/~npehk/MP3_utilities.zip
The only thing you need from the software is the amvtransform.exe under the AMV tool folder, you need to use it to convert any video type file into amv format before putting them on the player for playing video.
How to convert DVD to AMV format ?
By pchan in forum DVD RippingReplies: 5Last Post: 13th Dec 2011, 07:42 -
Best Way To Convert DVD, AVI to AMV Format
By dougwx in forum DVD RippingReplies: 5Last Post: 26th Nov 2011, 11:55 -
AMV Converter?
By LCE in forum Newbie / General discussionsReplies: 10Last Post: 18th Dec 2008, 13:30 -
Converting video files to .AMV format problem.....
By TheGMan in forum Video ConversionReplies: 2Last Post: 26th Dec 2007, 02:45
