VideoHelp.com Forum
    which one is better?
    If this is obvious then you all would have a field day on this
    I observed that few Dvd camcorders don't have a ilink interface. What's the reason behind it.
    How's My English?
  2. Member edDV's Avatar
    Obvious -- MiniDV is better for a few months to years.
    See this link for hard drive MPeg2 to start:
    http://forum.videohelp.com/viewtopic.php?t=300669
    DVD camcorders record a compressed MPeg2. If all you want is shoot to DVD it might be OK. If you want a higher quality acquisition optimized for editng, DV is what you want.
    MPeg2 DVD is more difficult to edit and the starting quality is less.
    When DVD camcorders were announced, Sony said customers for this format do not want to edit on a computer. It is possible to edit but is it not as easy as DV.
  3. Member MJA's Avatar
    MiniDV all the way
  4. Member slacker's Avatar
    I'm also sitting in the miniDV tape loyalty section. However, with Panasonic and Sony announcing support for the AVCHD codec (18 mbps) and the oncoming 'attack' of the dvd and hd based camcorders, I'm afraid miniDV may be doomed. Anyone see another future path?
  5. Member edDV's Avatar
    25 Mbps DV and HDV are the near future. 4-8 Mbps MPeg2 (DVD and HDD media) are the lower end alternative.
    Next, a hardware encoded MPeg4 standard is likely. The camcorder will record at an editable medium bitrate (SD or HD). AVCHD might be it. I'd expect the 8cm DVD to be quickly dumped in favor of solid state flash media. After editing 4-9Mb/s Mpeg4 H.264 is the likely distribution DVD standard.
    24fps progressive would be a disaster for handheld home camcorders. The standard will probably remain 29.97 or 25 fps interlace with optional 59.94 or 50 fps progressive.
  1. separate individual clips fused by dvd camcorders
    By codemaster in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th Apr 2012, 10:45
  2. How are DVD camcorders for editing their ouput?
    By brassplyer in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 16th Aug 2009, 00:16
  3. MiniDV vs memory card camcorders - what's the difference?
    By OM2 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 24th May 2009, 14:09
  4. Newb questions - re. HD&MiniDV Camcorders & Capture
    By The Big Cheese in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 1st Jan 2009, 17:21
  5. What camcorders are best, inexpensive for making Instructional DVD's?
    By scenicworld in forum Newbie / General discussions
    Last Post: 10th Dec 2008, 07:29
