I've been looking for some kind of software where I would be able to select (for example) My Documents and Settings folder and have it split in DVD sized or CD sized folders.
Does anybody know of any software that does that or somthing like it?
Thanks in advance.
Jason
Thread: Split files\folders into DVD's?
WinRAR and/or WinZIP spring to mind (both should have 'No Compression' options so that extraction time isn't a problem).
I'm assuming it's for backup purposes ?If in doubt, Google it.
If for backup purposes why not just use backup software? Your Profile doesn't say so you could be using Win 2000 or Xp. For Windows Xp this MS link may be of help.
http://www.microsoft.com/athome/secu...howbackup.mspx
In short it is installed in XP Pro and installable fro XP Home.
The reason that I cant use the backup built into windows xp is, sometimes the data is one a harddrive connected to my computer so all I have to work with are the folders.
There has to be some kind of software that splits folders up into whatever size you want so you can burn them to a dvd or cd.
BTW I am running XP.
My apologies, but I don't follow what you're trying to say hereOriginally Posted by Crash-n-Burn
Could you elaborate ?If in doubt, Google it.
Split Avi to DVD creates Video_Ts folders w. garbled video intro. Help?
By wildgeese in forum ffmpegX general discussionReplies: 7Last Post: 10th May 2011, 17:56 -
Folders changed into 32 kb files, help!!
By caesarhawy in forum ComputerReplies: 1Last Post: 27th Apr 2011, 13:57 -
No BDMV Or Certificate Files/Folders
By PM5K in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jun 2010, 03:14 -
Multisession DVD Burner and Burning Files into Specific Folders
By Disco Makberto in forum ComputerReplies: 9Last Post: 23rd Feb 2010, 01:48 -
help recovering DVD folders n vob files from deleted hard drive
By grafixx in forum ComputerReplies: 1Last Post: 16th Jan 2010, 14:44
