I was just wanted to know if it is possible to upgrade a Panasonic DMR-E85H (UK) hard drive.
I suppose I could get the same effect by buying a load of DVD-RAM discs, but I am lazy,
and would prefer to have the extra capacity in a form where I do not have to get up and change discs :P
I did have a search of the forums, but couldn't find anything relating to upgraging this perticular model.
Then you probably can't do it.....
You can try, most that would happen is you'd only be allowed the same amount of size as what you already have.
Well I have a 100gb hard disc spare, I will try it out.
I know that an extra 20gb isn't much, but at least if it works I will be able to buy a bigger disc, and if it dosn't work then I havn't lost any money.
From what I've read elsewhere, it will partition the drive to the same size as the original.
DMR-E80H Panasonic - Hard Drive replaced -also- transfer video to computer
By meowyann in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Jul 2010, 16:51 -
Backing up Panasonic DMR-EH60 hard drive contents
By Jonesy127 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Mar 2009, 11:42 -
problem with TV GUIDE on Panasonic DMR-E85H
By ktnwin in forum DVD & Blu-ray RecordersReplies: 6Last Post: 29th Oct 2007, 16:43 -
Really Strange Panasonic DMR-E85H Problem
By dafoe in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Aug 2007, 09:04 -
Question with Panasonic DMR-EH75V...putting videos on hard drive
By tucold in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th May 2007, 09:34
Statistics
Newest guides
Latest tool updates
New media comments
