OK so I just did something stupid, I was using DVD Shrink to backup a movie and instead of choosing DVD Decrypter as my final step I chose nothing and just created a folder that has the Audio_TS and Video_TS folders in it but now at a size that can fit on a DVD-R. I normally use DVD Decrypter as it is built in with DVD Shrink, but how do I burn this movie the way that I have it now. (I cant re rip it since I gave the DVD Back)
THANKS
Several options come to mind.
You could use Nero to burn the folders.
Or you could use DVDShrink to make an ISO file of those two folders and then burn with DVDDecrypter (this is the metihod that I use all of the time.)
Ed
Why can't you re-rip it? Where did you "give it back" where you can't get it again?
I would use Nero if you have it. Select 'DVD-Video' and drop the contents of your VIDEO_TS folder into the Nero VIDEO_TS folder. That's what I used to use before I started using DVD Decrypter or ImgBurn for that.
Using DVD Decrypter how would I burn the disk??????
"MY FRIEND" has the DVD Now thats why I cant borrow it again
this is the long way but it should work with what you got
use dvdshrink
instead of open disc go open files
then open the VIDEO_TS folder you have
there will be no shrinkage
select the correct output, i.e burn using dvddecrypter
hehethere will be no shrinkage
THanks for the help, next time I wont be so stupid and just use Decrypter the right way. THANKS
Audio_TS & Video_TS what they mean exactly?
By Deadmoney in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2011, 11:31 -
How do I burn Video_TS & Audio_TS files using DVDFAB?
By slayerbizkit in forum DVD RippingReplies: 8Last Post: 22nd May 2011, 19:18 -
Duplicate a DVD....can you simply copy Audio_TS folder and Video_TS folders
By True Colors in forum Authoring (DVD)Replies: 6Last Post: 29th Apr 2010, 14:37 -
AVI to DVD not outputting Video_TS or Audio_TS folders
By threesixes in forum ffmpegX general discussionReplies: 18Last Post: 30th Dec 2008, 01:23 -
How do I rip DVD to VIDEO_TS/AUDIO_TS folders?
By Crimea in forum Newbie / General discussionsReplies: 6Last Post: 18th Feb 2008, 11:34
