VideoHelp.com Forum
    Hi Everybody,
    Hope I am in the right forum.
    I am the coordinator of video evaluations of football games in the best danish leauge. We are using a video software for evaluating the games and therefore we need a file on the computer. We are also limited by that we need to distrube the games between the evaluating group.
    We get the games on DV tapes and each game is around 2-3 hours. The DV-avi file is huge, and we would like if its possible to have a file that could be burned into a normal DVD. The quality is not that important, be still we wanna have decent quality.
    So my questions, is this possible?
    How to do it? What software do we need?
    Hope anyone is able to help me!
    Yes, it's possible. Simplest method would be a DVD recorder. Get one with incremental recording periods and you should be able to get pretty good quality. It is also faster than the PC method as will be essentially real time.
    Otherwise, look at CCE basic, Procoder Express or tmpgenc as possible sofwtare encoder to do this for you.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. There's a few options depending on what you need it to do.
    TV and computer playback?
    http://www.videohelp.com/tools?tool=vso_DivXtoDVD Free and simple solution but with limited options. Quality isn't great but adequate. You certainly can't complian about the price.
    Computer only playback?
    Open up Windows Movie Maker, which should be installed on your computer if you have a Windows machine. Drop the clip on the on the timeline, click the create video file button. This creates very small files, depending on the settings you pick you can reduce a 14 gig DV-AVI to about 1-2 gigs with almost the same quality. This is only good for playback on the computer though.
    thecoalman and guns1inger,
    Thanks for your answers. I am still working on it, but now i had to turn my computer in for some repair. But again thanks for your answers.
    Does anyone know how much a DV-avi can be compressed using DivX?
  5. Member ZippyP.'s Avatar
    How long is a piece of string? As much as you like.
  1. Convert DVd to xvid avi best quality for max size 900mb
    By selwyns2828 in forum DVD Ripping
    Last Post: 10th Feb 2011, 17:02
  2. Replies: 0
    Last Post: 26th Oct 2009, 02:56
  3. Replies: 3
    Last Post: 10th Aug 2008, 16:07
  4. 3gp to avi decent quality requires iTunes, Dr DivX and Virtualdub!
    By Dannyfoster in forum Newbie / General discussions
    Last Post: 4th Jun 2007, 15:51
  5. Replies: 19
    Last Post: 25th May 2007, 04:59
