I've made a DVD with DVDLab Pro, and in the movie options I've created 2 audio links (English and Spanish) and 2 buttons, one to activate the subtitles and another one to deactivate them...
But the button that must deactivate the subtitles is not working, I press the button, and then resume the movie (with a button I've created) and the subs are still there...
How can I link this button to deactivate subtitles ???
Please this is urgent!!!
PD: Sorry my bad english, I speak spanish
Does your DVD player set any subtitles on by default ? You might not be able to override this from DVD Lab Pro.
Otherwise, describe the steps you followed to make the buttons.
Mmm I will show some screenies... My english is not very good, so I think I could explain it better with images:
1st.- This is the Connection windows, as you can see, it shows all the transitions in there, and the 4 Menu windows, The Root Menu, Menu 11 (setup) and Scene Selection menu 1 and 2.
2nd.- Here is the way I put the link to deactivate the subtitles, actually is not working =( =( =(...
So, I think I must enter a VM Command in the VTS domain, but I don't know how to do it, I tried to make the command, but all I could get was an error saying that in the Menu 11 was a link that goes to nowhere or something like that...
So, What can I do to fix the issue with the deactivate subtitle link???...
You can add a VM command where you logically want to turn them off:
SetSTN (subp=0
ff)
Regards,
George
I actually do that, right to the button, but didn't work... I readed that the command must be in the VTS region so it can be recognised... But I tryed with no success... Mmmm Where should I put the command?? I know I can add it just right clicking on the button link, but when I compile the DVD I press the button and then resume the movie and nothing happen...
Anything???
Where did you put the command in the VTS region? try one of the pre-commands on the title in question (just to see if it will work)...
Regards,
George
URGENT == Can't upgrade to VOB2MPG PRO
By aodor in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 23rd Dec 2010, 17:27 -
URGENT: Need to output to ASP DivX w/ Multiple Subs, Audio Tracks, Chapters
By Jeet in forum Authoring (DVD)Replies: 0Last Post: 7th Oct 2010, 16:14 -
Urgent! Please help! Panasonic S-VHS Reporter and Adobe Premiere Pro
By urdeluge in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 16:00 -
VCD to DVD with subtitles in DVDlab Pro - subs 'disappear'...
By nbarzgar in forum Authoring (DVD)Replies: 0Last Post: 11th Jun 2007, 10:16
