Hi ,
I like to join few mov files. I find “Open Video Joiner” but it reencode the video. So im looking for an application that joins moves without the need to reencode it. Any idea?
tx
Not counting QT Alt.,
ALL apps that work with Quicktime MOV files, do so by using Quicktime. The best thing for this then is QTPro.
Even then, unless it's actually an MP4, you might still be in trouble.
You have 2 choices--SaveAs and Export. SaveAs will do exactly as you want, but it does it by creating a 2nd "layer" of video, muxed along with the 1st. Most apps shouldn't have trouble reading this file, but you never know.
The other option, Export, will invariably re-encode, unless you happen to be using the same codec and have no changes to the video, and then it has to recognize the fact that it can losslessly "transcode" (not the correct term in this case, but that's what THEY use), which you should then check the box for. This works for QT-DV, but I don't know about the other codecs.
Good luck,
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 2Last Post: 11th Mar 2012, 19:42 -
How to join mov files?
By Espen in forum EditingReplies: 54Last Post: 19th Dec 2011, 06:13 -
Join MOV Video from command line
By parisisal in forum EditingReplies: 4Last Post: 19th Feb 2009, 10:59 -
Join mov files and upload to youtube
By neelapala in forum EditingReplies: 2Last Post: 23rd Dec 2008, 11:09 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 03:37
Statistics
Newest guides
Latest tool updates
New media comments
