hi,
anyone knows how to edit .srt font and color?
I just successfully hardsub a movie using virtualdubmob = avi (hardsub)
but the outcome is the usual white color font, how can I change the font color to yellow or green cause from what I read it more readable.
Is there any software that I can use to first change (.srt) its color and font before using virtualdubmob for hardsubbing???
any easy procedure?, cause Im not that good in computer, it took me ages to follow "Baldrick-how to add permanent sub using virtualdubmob" instruction.![]()
I tried subtitle workshop but dont see any option in changing colors.
thanks
Results 1 to 20 of 20
Thread: edit subtitle's font and color
Yeah, I don't think you can change those things with an SRT format sub file. I change them to SSA (SubResynch, which comes with the VobSub package will do it, as well as many other apps) and then open them in SubStation Alpha where you can change font, color, size, position, etc. fairly easily. Then you can encode with the SSA subs, burning them into the video and keeping the font, color, etc. as you set them up.
Good old Notepad will do quite nicely too, once you understand how .ssa works.Originally Posted by manono
/Mats -
Forgive my bad english
You can change your colors letters directly from your movie in the HD with IfoEdit
IfoEdit>>open your movie>>click VTS_PGCITI >>click "+">>click VTS_PGC_1
In the below window look for this lines
Color 0 Y Cr CB (<<background)
Color 1 Y Cr CB (<<contorns)
Color 2 Y Cr CB (<<letters)
Color 3 Y Cr CB (<<antialias)
Click twice on the third line (Color2 Y Cr CB) and change this for d2 92 10 (this is for yellow),
click OK, and then SAVE >>select the SAME IFO file that opened your video and click save
Thats all, now you have a yellow letters
I use this settings for my subtitles
10 80 80 (black background) (transparent)
28 bd ef (blue contorns)
d2 92 10 (yellow letters) (eb 80 80 for white letters)
7d 80 80 ( grey antialias) -
True, but that doesn't really apply to a hard subbing an AVI - but good info on how to change subtitle colors for DVD subs.
/Mats -
OK .. But How Do I change the Subs color just using IDX files and SUB files?? Just edit the IDX file in Notepad and I'm good to go?
OK Found this:
Whilst editing the IDX file in Notepad:
# The original palette of the DVD
palette: 4c5c05, b9de12, 000000, fdfdfd, e5f842, ee4ac6, fdfdfd, fcfcfc, 0d60da, fafaf8, f9f9f7, f8f8f6, f6f6f4, f6f6f4, f5f5f3, f4f4f4
This is what I have in my Original DVD IDX file .. Which is in Yellow color ..
I found this in this post
When I interchanged this in the IDX file, Voila! I got the blue Black subtitle color..# The original palette of the DVD
palette: 000000, 121212, 6d6d6d, d9d9d9, 000000, 121212, 848484, cacaca, 111111, 9a9a9a, ffffff, 828282, 828282, 828282, 828282, 828282
So here's what I want to know..
Is there a reference table for DVD Subs colors like this?
For EG:
Black --> Corresponding Code
Blue --> Corresponding Code
Blue-Black --> Corresponding Code
White --> Corresponding Code
Red --> Corresponding Code
and is Yellow color OK? Won't it bad for watching on the telly.
What color do you guyz suggest so that it is pleasant? -
I'm not sure about the format (if it's RGB or the format in the IFO) but I think it's rgb.
Then:
Black --> 000000
Blue --> 0000FF
Blue-Black --> 000080
White --> FFFFFF
Red --> FF0000
Same as format as HTML colors, actually.
/Mats -
There are a bunch of charts available to give you the color values:
http://www.mrs.umn.edu/committees/wwwac/toolbox/color.html
http://www.december.com/html/spec/colorsafe.html
http://www.hypersolutions.org/pages/rgbhex.html
I still say it's easier to change the IDX/SUB format colors using VobSub Configure.
And SUP format subs can be changed using DVDSubEdit.
About the only time I like yellow for subs is when watching anime. I prefer a nice grey color for live action movies -
Hi, sorry for bumping such an old topic.
I have a problem with changing the colours of the subtitles. Some of my videos have white subtitles while some have cyan. I would like to change them all to white. The subtitles are in .idx/.sub format. What I have did is to try and modify the .idx file.
Those videos that have the white subtitles have these lines in the corresponding .idx file:
palette: e83f07, e19120, f3c71b, f8ff18, 9bd22a, 54a530, 12eb12, 15bef6, 0300e3, 4c0353, c12262, ffffff, b3b3b3, 808080, 4e4e4e, 000000
# Custom colors (transp idxs and the four colors)
custom colors: OFF, tridx: 1010, colors: ffffff, ffffff, 808080, 000000
Those that have cyan subtitles contain this:
custom colors: ON, tridx: 1010, colors: ffffff, ffffff, 808080, 000000
Notice that the custom colors line is different, one being OFF... and one being ON.... What I have done is change the custom colours: ON to OFF in the .idx files that gave rise to cyan subtitles. That didn't work, that is, the subtitles are still cyan in colour.
Even with that difference, some of the videos that have white subtitles contain "custom colors: ON..." in their corresponding .idx file, which i think is pretty weird. Could it be that is not the line that is affecting the subtitle font colour?
So I have tried using VobSub configure. I'm not exactly sure how to use it, but I did play around with the settings a little, but the cyan subtitles remain.
Any help would be appreciated. -
Easiest way is DVDSubedit. It can change colours in the VOBs and IFOs, or in SUP files (you can convert SUB/IDX to SUP if you need to).Originally Posted by sooojaded
You change one, then "Edit/Apply last modification to all" will do as it says. -
Thanks for your prompt reply. Actually, I don't mind going through all the trouble of changing each file one by one, but I would really like to keep the format as it is. That is, keeping it as .idx/.sub format. DVDsubedit does not seem to support these formats. I would really like to know what are the areas in the subtitle files that are directly determining the colour. Thanks though.
As I said, you can convert SUB/IDX to SUP (with SubToSup).Originally Posted by sooojaded
Then you can use tools like Supviewer or DVDSubedit to change the colours.
Most authoring apps support SUP format (with a palette file).
I don't know any tools that can do this for SUB/IDX, though there may be.
Of course, DVDSubedit can change the colours after you author to VOBs. -
After opening the IDX in VOBSub Configure, check the "Custom Colors" box. If you see that cyan color, click on it and change it to white followed by "OK". If you don't see it, I'm not positive as I don't have a 2-color IDX with which to test, but I'd check the drop-down box at the top for something different.So I have tried using VobSub configure. I'm not exactly sure how to use it, but I did play around with the settings a little, but the cyan subtitles remain.
If that doesn't work, I'd go the DVDSubEdit route. Change to SUP format (SubtitleCreator is what I use->Tools->Manipulate SUP or VobSub->Open Sub (open the IDX/SUB)->Save Sub (Save as SUP). Then open the SUP in DVDSubEdit. Now, SubtitleCreator can also change the IDX/SUB colors, but if VobSub Configure doesn't show the cyan one, I don't think SubtitleCreator will either. Once in DVDSubEdit, scroll around until you find a cyan sub and change it to white. Then Edit->Apply last modifications to all to all->File->Save All Modifications. Then back to SubtitleCreator to change the SUP back to IDX/SUB.
This is, admittedly, kind of a roundabout way to do what you want, but short of just removing those 2 lines in the IDX (did you try that?), I can't figure a way to do what you want. -
I have figured out a way to change the cyan subtitles to white without having to download any programs. I experimented with some of the colour settings, and I have found out something.
This line in the .idx file:
I changed it to:
palette: e83f07, e19120, f3c71b, ffffff, 9bd22a, 54a530, 12eb12, 15bef6, 0300e3, 4c0353, c12262, ffffff, b3b3b3, 808080, 4e4e4e, 000000
I got white subtitles after that. Its pretty weird that some .idx files with "f8ff18" in the fourth tier already display white subtitles in the corresponding video.
I did try that. I even changed it to red and other weird colours. I also fooled around with the transparency thing and scale. The videos still displayed cyan subtitles. As for Dvdsubedit, I felt that doing so would be a hassle, so I dropped the idea.After opening the IDX in VOBSub Configure, check the "Custom Colors" box. If you see that cyan color, click on it and change it to white followed by "OK". If you don't see it, I'm not positive as I don't have a 2-color IDX with which to test, but I'd check the drop-down box at the top for something different.
AlanHK, I did not know that .sup files can be converted back to .idx/.sub until manono said so, hence I was unwilling to take your suggestion. Sorry about that.
Thanks a lot for your rather detailed suggestions though. I would still keep them in mind in the future.
Subtitle font color
By stem300 in forum SubtitleReplies: 3Last Post: 12th Dec 2011, 13:30 -
Changing font size/color for hardcoded subtitles
By JMantis in forum SubtitleReplies: 4Last Post: 6th Mar 2011, 19:34 -
Changing Srt Font and color
By Soixante in forum SubtitleReplies: 7Last Post: 26th Apr 2010, 12:55 -
DVD subtitle font, color and size
By Charmer in forum SubtitleReplies: 3Last Post: 25th Apr 2010, 17:06 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 16:38
