Ave,
I'm curious about something.
I recently bought the RCA D52W23 52" HDTV... and i know it's a cheap TV but it's giving me awesome performance so i have nothing to complain. The picture is crystal clear and i have no problems with it at all.
I use AR Component Cables to hook up my DVD Player to my TV.
And i use DVI to hook up my HD Cable Box to my TV.
I ran the HDTV Setup Wizard on my Cable Box (Time Warner / Scientific Atlanta) after i hooked up my Cable Box to my TV, using the DVI Cable. In the Setup i found that 1080i, 480i & 480p were brilliantly visible on the TV, and so added those to my selection. After which the Setup Wizard informed me that i will be able to choose one of my selections from the "Settings" menu whenever i'm seeing my Cable TV.
The problem is, when i go into the Settings menu while watching Cable on my TV, i get 480i & 480p in the options... but i don't get 1080i in the options.
The picture is perfect and its' crystal clear... i dont' have any problems... but i'm curious why i'm not able to see 1080i in my Setting Menu for the Cable Box. This TV natively supports the 1080i format... and i was able to view it & add it during the Setup Wizard. The only problems i had viewing were the 720 formats so i never added them. 1080 & 480 were fine.
So where did the 1080i format go?
Thanks,
Mickey
Results 1 to 1 of 1
Thread: 1080i on HDTV D52W23
I don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
I enjoy every moment of it!
1080i hdtv transcoding issues
By topsyturvy in forum Video ConversionReplies: 9Last Post: 1st May 2011, 05:49 -
Convert HDTV 1080i to DVD5
By marvell in forum DVB / HDTVReplies: 6Last Post: 24th Mar 2010, 06:19 -
HDTV: 1080i or 1088i, which is it ??? .. (SOLVED)
By vhelp in forum DVB / HDTVReplies: 12Last Post: 3rd Feb 2008, 21:53 -
1080i on 32" HDTV's with 1366x768 res. ??? how?
By snadge in forum Newbie / General discussionsReplies: 32Last Post: 13th Jan 2008, 10:47 -
Convert 1080i .mpg to hr.hdtv (960x540 xvid)
By MrFingers in forum DVB / HDTVReplies: 4Last Post: 6th Aug 2007, 09:00
