I have tried numerous times to download the mpeg2enc file in binary but it constantly downloads in text. I have tried using Control-click on the various links with no luck. When I use Control-Click i do not get the download to disk option but only download link.Can someone help me find a binary source or advice for how to download it or email it to me. Also I am just starting out in conversion to Archos format so I could use some advice in that regard.
thanks
mick41
Sounds like Safari being stubborn. Firefox doesn't add the '.txt' suffix.
The Safari downloaded file is fine, tho', if you remove the '.txt' in the Finder Get Info's Name & Extension field. (HexEdit's Compare Files command shows the files by two browsers to be binary exactly the same.)
If the developer could put the old 'mpeg2enc' file and the new 'mpeg2enc.intel' file in a zip or dmg container, that would help end users, imho.
mpeg2enc binary not working
By yabastamedia in forum ffmpegX general discussionReplies: 1Last Post: 19th Jan 2011, 12:02 -
Problem opening mpeg2enc binary
By itegil in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2010, 22:48 -
Can't install mpeg2enc binary
By cpwhaley in forum ffmpegX general discussionReplies: 3Last Post: 23rd Jul 2008, 13:50 -
Problem with mpeg2enc binary
By lkearl in forum ffmpegX general discussionReplies: 1Last Post: 11th Aug 2007, 03:47 -
mpeg2enc binary link does not Work
By loveformetal1 in forum ffmpegX general discussionReplies: 5Last Post: 6th May 2007, 06:40
Statistics
Newest guides
Latest tool updates
New media comments
